how to remove water spots
I recently just washed my car, then i went outside to check on it the other day and i had forgotten to dry a stream of water on the side of my car. Now it left a water spot stain and it wont come off!! I need help on how i can remove it. My car is silver to u can see it easily to. Its just a white stream going down the side of my car, its not too big but noticeable. Help please!!
I've got spots on my spoiler and it won't come off as well...I even tried claying it a few times but the clay just left additional marks (should have used more lubricant). But either way, the spots didn't come off. I'll go to the store to grab some white vinegar today and then I'll try it tomorrow morning before I wash the car.
Do I just blot the vinegar on the spots and let sit for a minute or do I just pour the vinegar on the spot?
Damn! I tried to clay, then tried white vinegar and nothing seems to work! I'll post a pic of the spots when I get the chance, but looks like I can't get it out. Maybe I need to keep rubbing the clay on it...but I did it for a little while and it dosn't seem to do much. Any other suggestions? Dawn the whole car and start my Zaino treatment over again? Will Dawn even remove the Zaino?
Clay bar WILL work
Water spots will come off with a clay bar. Make sure you are in shade and a cool spot. Also be certain to use the clay mist; if you don't have the mist, go to Advance or Auto Zone and buy the Clay Magic brand kit (kit = clay bar and mister).
Mist the area and use the clay bar until the spots are gone; you may need to do multiple applications.
alright cool, thanks alot ill have to try it and let ya know, it has really been irritating me and i thought it was under my tint ..however its on my winshield and theres no tint on there so it cant be. thanks alot
Sucks, the water spots couldn't be taken out by claying. I tried blotting with white vinegar, but it didn't help. Then I washed the car and tried to clay it....didn't help either (also used the soapy mix to lubricate it). What else can I try other than a full buff and wetsand?
Gsr, the waterspot may be under your Z so strip your Z off your spoiler and than try claying / vinegar if the waterspot was on your Z the Z quick detail spray woulda taken that spot off with minimal effort. If that works , great! But that means you need to do a better paint prep for your Z nextime. If it dosent work, read below.
It may be lightly etched into your clearcoat if it wont easily lift off. everything youve done , claying and such should have worked at removal if the spot was just sitting on your paint, check the spots out in some good lighting and run your fingernail over the spot, if you can feel the edges of the waterspot than its etched in. A light polish should be able to fix that pretty quickly no need to break out the sandpaper
Can't feel the spots, but they are there. Anyone have tips on removing Zaino? I am not going to just do the spoiler, I'm gonna remove the Zaino on the whole car and start all over. Will Dawn remove the Zaino?
I'm quite surprised that it did considering I had 15 coats of Zaino...over a 1 year period.
But it's just weird...it's only on the spoiler...from the splatter patterns, it should've gotten on part of the trunk and the bumper. Unless it's different paint and different plastic on the spoiler.
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
STL TL-S
Sep 23, 2015 08:52 PM
