Glaze- Does it add shine??
So I'm curious about getting some glaze to top on my 4*UPP to give it some extra shine. I just did a quick search on google and came across an arguement on another forum that glaze does nothing for it if a car has been polished perfectly. But they don't state the time frame of when the car was polished last.
My question is this true? Does this still hold true after say 6 months if proper wash and up keep steps are taken ie spray and wax and more apps of 4*UPP.
Just trying to justify if spending more money on some glaze will enhance the look of my car or would it just be redundant since I may have reached full gloss capacity...Yes I think some pictures might help answer the question but I don't have any current pictures at the moment.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
I am waiting to try my DWG however everything I have seen has definitely increased the shine on all the examples I've seen, I think you would want to put the glaze under the UPP though, but I'm not 100% sure
Here's my take on most glazes out there. Some claim they are designed to fill in imperfections and help increase the depth and gloss. I find that the filling on any glaze I've used is pretty minor and most people who use a glaze are disappointed when it comes to filling swirls. I have experienced some increased wetness and depth with some glazes on some paint.
I only recommend a glaze when someone doesn't have a quality buffer to polish with. Personally, I'd rather spend that extra time and effort doing a second coat of polishing or burnishing the paint rather than applying a glaze, but if one doesn't have the proper tools and products to polish, a glaze can come in handy. The better you polish, the less impact a glaze will have IMO.
There aren't a ton of glazes that work well with sealants, Chemical Guys EZ Creme Glaze and DWG are two that do since they are acrylic based.
Popular glazes such as ClearKote Red Moose Glaze do help increase the depth and gloss, but should only be used under a carnauba wax since a sealant has a difficult time bonding to it.
Glazes serve a purpose when used properly.
George
George
Former Sponsor
Im going to clean up a little mysteria here.
Glazes, as I know them are for a temporary enhancement of paint depth. They also provide temporary filling of very small voids and swirls in the paint surface area. They contain enrichening oils and fillers, often finely filtered, non abrasive clays.
What makes glazes attractive, are the oils they contain. Not until the oils are buffed dry and clear will they reveal a nice gloss. As for gloss enhancing? Its like putting furntiure polish on dry wood. Its going to make a difference, until the oils soak in, or evaporate. Put furniture polish on glossy wood, and it adds a little more shine. again, until it soaks in or evaporates.
DWG or CG EZ Creme, IME has always been put on, in the end, after the UPP or 105.
Theoretically, if your using an LSP that has light cleaners, you would use the glaze atop it for obvious reason that the cleaner would minimize the glazes appearance if put on last.
Former Sponsor
If its put on correctly, you can do the entire care. I like doing the front section (doors------> bumper) then removing, then doors and roof, then rear section.
Former Sponsor
If it were me.....I'd wash, dry, UPP (if theres only 1 coat).....Following day, glaze it. The EZ Creme and/or DWG does provide Acrylic protection, but its not like UPP! Maybe a month of additional protection tops......
Don't do an alcohol wipe as it will remove the UPP ... Alcohol wipe is only used after polishing and prior to your first layer of sealant to produce an oil free clean surface.
emailnatec
29
09-28-2018 04:27 PM
soupi
14
11-15-2015 11:15 AM
