Anyone use this?
Anyone use this?
Was just looking at clay bars and came across this product. Wondering if anyone has any expierence with it.
http://www.autopia-carcare.com/ult-3200-3322.html
FTW
Sonus SFX Ultra-Fine Detailing Clay-
When used as directed for regular maintenance, one bar of Sonus SFX Ultra Fine Detailing Clay will clean your vehicle’s paint 3-4 times.
Originally Posted by exceldetail
Your missing the point. Does it perform equal or better to traditional clay?
FTW
I don't think anyone here knows how it performs.. so time will tell.
Originally Posted by LoveMyTSX
May be worth buying if you can use it 20 times. Don't have to kneed it either.
http://meguiarsonline.com/forums/thread/10510.aspx
http://autopia.org/forum/detailing-p...ht=Elastrofoam
Former Sponsor
Dan, as far I as I know your able to wash it. I mean it may be the product of the decade, but as mentioned, a guinea pig and first class evaluation would be great!
Needs more Lemon Pledge
Looks like it leaves your LSP intact as well.
Now, most importantly, can I DROP it and still use it???
Looks like the same item, but manufactured by Hi-Tech industries called The Body Sponge
Here's a review from the Meg's Forum and is available from ADS for $12.95 or a two pack for $21.95.
This is an excerpt of an article on claying written by Jon (aka TOGWT) . . .
BHS-212 Hi-Tech Body Sponge™. New breakthrough product! Safely and easily removes rail dust, water spots, tar, bugs, and paint overspray from automotive paint and glass surfaces. Lubricate with any showroom shine.
- No kneading required
- If dropped on floor, simply rinse off.
- Use up to 30 times.
Alternative product- Hi-Tech Body Sponge™ this innovative rubber polymer product safely and easily removes overspray, water spots, tree sap, rail dust, bugs and other bonded surface contaminants from the surface of automotive paint, glass, mouldings and plastic, may be used with any kind of lubricant. Sponge retains soap and water and releases it as a lubricant when gently squeezed while gliding over the surface. Unlike detailer’s clay this product can be cleaned by simply rinsing off the accumulated contaminates with water or in a soap bucket. Accidentally dropping it on the ground is not a problem. Just rinse the sponge pad clean and you’re ready to keep using it. Easy grip sponge allows for sturdy and controlled handling, can be used up to 30 times before needing to be discarded. Hi-Tech Body Sponge™
