Anyone use this?
Old Jul 26, 2007 | 01:32 AM
probmxstyle's Avatar
Anyone use this?
Was just looking at clay bars and came across this product. Wondering if anyone has any expierence with it.
http://www.autopia-carcare.com/ult-3200-3322.html
Old Jul 26, 2007 | 07:30 AM
exceldetail's Avatar
Former Sponsor
Wow, thats nearly twice what a traditional bar runs......!
Old Jul 26, 2007 | 08:31 AM
LoveMyTL-S's Avatar
Can you get 20 uses out of a traditional bar?
Old Jul 26, 2007 | 09:28 AM
lusid's Avatar
FTW
How long does the regular clay bar last?
Old Jul 26, 2007 | 09:30 AM
lusid's Avatar
FTW
Sonus SFX Ultra-Fine Detailing Clay-
When used as directed for regular maintenance, one bar of Sonus SFX Ultra Fine Detailing Clay will clean your vehicle’s paint 3-4 times.
Old Jul 26, 2007 | 11:40 AM
LoveMyTL-S's Avatar
May be worth buying if you can use it 20 times. Don't have to kneed it either.
Old Jul 26, 2007 | 11:53 AM
Former Sponsor
Your missing the point. Does it perform equal or better to traditional clay?
Old Jul 26, 2007 | 12:09 PM
I guess I could be the guinea pig to find out
Old Jul 26, 2007 | 12:59 PM
lusid's Avatar
FTW
I don't think anyone here knows how it performs.. so time will tell.
Old Jul 26, 2007 | 01:35 PM
Hawhyen51's Avatar
You're saying you don't have to kneed it. My question is what does the Elastrofoam do with the collected contaminants? I don't have any info on this new product but here are several links that do talk about it. Mind you, I haven't read any of it (yet) and just passing info.
http://meguiarsonline.com/forums/thread/10510.aspx
http://autopia.org/forum/detailing-p...ht=Elastrofoam
Old Jul 26, 2007 | 03:06 PM
Former Sponsor
Dan, as far I as I know your able to wash it. I mean it may be the product of the decade, but as mentioned, a guinea pig and first class evaluation would be great!
Old Jul 26, 2007 | 04:30 PM
stogie1020's Avatar
Needs more Lemon Pledge
Looks like it leaves your LSP intact as well.
Now, most importantly, can I DROP it and still use it???
Old Jul 27, 2007 | 12:36 AM
Since its washable I dont see why not.
Old Jul 29, 2007 | 11:26 PM
Jesstzn's Avatar
Is the lube just a QD spray or is it special and going to run out before the bar does?
Old Jul 30, 2007 | 10:16 AM
Hawhyen51's Avatar
Looks like the same item, but manufactured by Hi-Tech industries called The Body Sponge
BHS-212 Hi-Tech Body Sponge™. New breakthrough product! Safely and easily removes rail dust, water spots, tar, bugs, and paint overspray from automotive paint and glass surfaces. Lubricate with any showroom shine.
  • No kneading required
  • If dropped on floor, simply rinse off.
  • Use up to 30 times.
Here's a review from the Meg's Forum and is available from ADS for $12.95 or a two pack for $21.95.
This is an excerpt of an article on claying written by Jon (aka TOGWT) . . .
Alternative product- Hi-Tech Body Sponge™ this innovative rubber polymer product safely and easily removes overspray, water spots, tree sap, rail dust, bugs and other bonded surface contaminants from the surface of automotive paint, glass, mouldings and plastic, may be used with any kind of lubricant. Sponge retains soap and water and releases it as a lubricant when gently squeezed while gliding over the surface. Unlike detailer’s clay this product can be cleaned by simply rinsing off the accumulated contaminates with water or in a soap bucket. Accidentally dropping it on the ground is not a problem. Just rinse the sponge pad clean and you’re ready to keep using it. Easy grip sponge allows for sturdy and controlled handling, can be used up to 30 times before needing to be discarded. Hi-Tech Body Sponge™
Old Jul 30, 2007 | 12:45 PM
LoveMyTL-S's Avatar
Hmmmm I may try this myself. Good find Hawhyen51
