D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
94 DC4 RS LSV/Turbo
Yes that is right... another thread to avoid excessive new threads
Please follow this format to get a quick and accurate reply
Questions on Wheels
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
If lowered (amount):
Question on Brembo/Big Brake Clearance
Transmission (Manual or Auto):
Year/Trim (04-07, Base or Type S):
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
Questions on Tires
Tire Make/Model:
Width/Sidewall-Diameter (***/**-**):
Need a spacer?
For 5mm H&R/Eibach or Ichiba work
For 5mm or greater visit wheeladapter.com (custom widths available)
Extended Wheel Studs are always the best way to go
Questions on Wheels
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
Questions on Tires
Tire Make/Model:
Need a spacer?
great idea.
Looking for new mods
Question on Brembo/Big Brake Clearance?
Transmission :Auto
07, Base
Wheel:Enkei/Ame Tracers FS01
Wheel Size:Wheel 19x8.5, 5x114.3
Wheel Offset :40 or 30
If lowered:Possibly on neuspeed...you know which ones
Transmission :Auto
07, Base
This is a bump. Those of you who have questions in regards to wheel/tire fitment issues.
Please post here to keep this section clear, Allon (Stillhere153) will answer your questions. (If I know the answer I may buzz in. Hope you dont mind Stillehere!!)
Questions on Wheels
Wheel Make/Model: Work Varianza T1S
Wheel Size (**X**): 19x8.5
Wheel Offset (+**): (not sure) 42?
If lowered (amount): 1 inch
Do you guys know what the largest offset we can get away with without sacraficing the setting on the car yet maximizing the lip size for wheels? I'm running a base 07 TL AT so I don't have Brembo's. The larger the lip the better but I also don't want to rub the calipers. Since these are custom build I can pretty much specify an offset. I just wanted to make sure I was able to maximize the lip size.
Originally Posted by pellepelle_10
Questions on Wheels
Do you guys know what the largest offset we can get away with without sacraficing the setting on the car yet maximizing the lip size for wheels? I'm running a base 07 TL AT so I don't have Brembo's. The larger the lip the better but I also don't want to rub the calipers. Since these are custom build I can pretty much specify an offset. I just wanted to make sure I was able to maximize the lip size.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
FizzyStatus!
Originally Posted by Fulani has a TL
You can run a +35 offset without any issues of rubbing. And if you ever do decide to drop lower, its been proven (by Jay - Distorted Reality) That you can tuck if you run 225/35/19s.
94 DC4 RS LSV/Turbo
Questions on Wheels
if you want a larger lip... 19x9 all around would work with a +40 offset ideally... but you can go as low as +38 and run 245/35-19... with an offset betwen +40 and +45 you can run 255/35-19
lets keep this on topic guys... no clogging tho
JD TL-S (12-02-2011)
I just wanted to get as close to a 3" lip as possible without doing a 9.5 wheel. Just wondering if I can fart around with the offset a little to have a larger lip for the whip. I'm only doing moderate drop. I want to be able to ride 4 peeps in the car without my stuff dragging the ground.
Originally Posted by stillhere153
thanks for the bump, but "allon" is blackura... I am just "Al" as in short for Alfredo...
lets keep this on topic guys... no clogging tho![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Sorry Al
yeah i didn't want to feel every crack in the road so I was going to go 235/35/19. My boy has 245's and he was saying it felt rough even going that way and he has stock type-s suspension. lol
I just wanted to get as close to a 3" lip as possible without doing a 9.5 wheel. Just wondering if I can fart around with the offset a little to have a larger lip for the whip. I'm only doing moderate drop. I want to be able to ride 4 peeps in the car without my stuff dragging the ground.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
In regards to the 245s, It comes down to which tires you want, the softer materials will def. make you feel more, whereas the UHP A/S will have you feel less.
But since you are thinking about getting 2pc you should be able to go low disk on both ends, and still clear your stock brakes, which will give you a nice lip. And like Al said you can go with a 9" wheel, But If you are running stock brakes (ie not the brembo brakes) You can actually run +35 since your drop is going to be just 1".
My recommendation, find an aftermarket wheel shop who is willing to work with you and do some test fits. That way you can be positive before you make such an investment
Scuba_Steve
Question on Brembo/Big Brake Clearance...
Sorry I got a few wheels to ask about...
Auto
'07 Type S
Make: R1 Racing wheels / Model: Hype
Offset: 35 or 25
Make: R1 Racing wheels / Model : Drift
Offset: 35 or 25
Make: ADR / Sterling
Offset: 38, 32, or 20
Will be lowered in the area of about 1.3"
Auto
'07 Type S
Offset: 35 or 25
Offset: 35 or 25
In the AM, in the AM
04 6spd
iForged aero
20 x 8.5 front
custom offset (they don't reveal offset?)
what size tire?
20 x 9.5 rear
once again custom offset
what size tire?
will be dropped using tein ss. can i go 2"?
iforged is suggesting I do 9" width on the rear as they think 9.5" will rub. I told them that I have seen a few TLs doing 10" rear without any problems. Do you guys think I should go with their suggestion? I like big lips so I am worried that the 9" will not look that different from the 8.5" in the front.
any help would be greatly appreciated.
iForged aero
20 x 8.5 front
what size tire?
20 x 9.5 rear
what size tire?
Auto
'07 Type S
Offset: 35 or 25
Offset: 35 or 25
Auto
'07 Type S
Offset: 35 or 25
Offset: 35 or 25
35 offset - need 3-5mm spacer
38 offset - should not have issues
Originally Posted by phenomengan
04 6spd
iForged aero
20 x 8.5 front
what size tire?
20 x 9.5 rear
what size tire?
iForged aero
20 x 8.5 front
what size tire?
20 x 9.5 rear
what size tire?
It is possible to run 9.5 in the rear, but you may not be able to drop 2" like you want.
iScrape going into
Originally Posted by bigmoetl1
want to run 20X8.5 menzari ms sport 245-30-20 what offset do i need 08 type s auto
Based on the offsets available for those wheels gotta go with +45 offset
also what about the u2 35 20X8.5 with 245-30-20 on 08 tl type s
do you have your mind set on the 245/30/20? If not you could run stretched with a 225/30/20 if you have plans on dumping your tl
wdp skyhawk
With this wheel gonna be close as they only have +38 as a viable option. May have to run a 3mm spacer with it.
NBP_BALLER (03-04-2013)
Herro
I'm pretty sure you remember me. But if not...
Questions on Wheels
Wheel Make/Model: MB Wheels Weapon
Wheel Size (18x9):
Wheel Offset (+38&45):
If lowered (amount):1.75" front, 1.5" rear neuspeed sport accord springs
Question is, you said the 38 offset would be aggressive but will fit. Discount Direct does not have an option of that for the TL, but have it supplied (guessing they think it won't fit the TL). How close of a fit would the 38 offset would be?
The look I'm really looking for is for the wheels to be flushed with the fenders.
Thanks Again.
Questions on Wheels
Wheel Size (18x9):
Thanks Again.
Since you have brembos up front, you want to do a high disk up front, and a low disk in the rear. With the low disk you will have a larger lip.
Questions on Wheels
Wheel Size (18x9):
Thanks Again.
Questions on Wheels
Wheel Size (18x9):
Thanks Again.
Me personally with your drop that you will I have, I would do the +38.
Need to look at it like this, if you do a +38 offset; your wheel will stick out 20mm (1inch = 25.4mm) compared to where your stock wheels are.
If you do a +45 offset in a 9" wheel your wheel will stick out 13 mm
should i be doing 245/30 up front and 255/30 in the rear with this setup?
The way I look at it, I was rolling with 245/35/19 on +35 offset wheels, had plenty of clearance. The Overall Diameter on those was 25.75, and section width was 9.64.
Now If I run 255/30/20 the Overall Diameter will be 26.02 and section width will be 10.03
and a 245/30/20 Overall Diameter will be 25.78 and section width will be 9.64.
I have a feeling I can run 255's up front, if not 255's then 245s for sure. Not like I am going to be able to slam anyways, cuz the rear won't allow me to slam or probably drop any lower than I already am, unless I run a negative 2 camber, which I dont think I will.
94 DC4 RS LSV/Turbo
thanks for the help fulani... I was away from azine doing some major installs on a fellow members car... fulani is pretty much on the money on all his replies
94 DC4 RS LSV/Turbo
245.30-20 works on an 8.5 +35 easy.... I have a front camber kit for sale if you'd like to have it sit perfectly on both sides
94 DC4 RS LSV/Turbo
ah, thank you Fulani.
I got the offset thingy down now with what you said. Thanks alot.
Should have these rims very soon...
Scuba_Steve
25 offset - need about a 13mm spacer (Not recommended)
What about if I do Falken Torque 5s at 19x8 with 38 offset, what tire size would be best?
