Transmission fluid via cooler hose
Old 06-02-2015, 08:22 PM
xBlue's Avatar
I'm aware of the 3x3 method and that's what I've done last time (30k) ago.
I was just taking to a friend and he said that there's a better way that not many people know about, except mechanics:
To replace the transmission fluid, you unplug the cooler hose going from transmission to radiator and start pouring new transmission fluid from the top until the transmission fluid going out is clean.
Has anyone heard about this? Is it better than the 3x3 method?
Old 06-02-2015, 08:29 PM
ggesq's Avatar
Received 2,181 Likes on 1,210 Posts
https://acurazine.com/forums/problem...method-906605/
Old 06-02-2015, 09:33 PM
xBlue's Avatar
Thanks @ggesq. Do you recommend 3x3 or the cooling method?
Old 06-03-2015, 08:21 AM
ggesq's Avatar
Based on what I have read here on AZ, I would do the cooling line method. Since you did a full 3x3 30k miles ago, you won't be shocking your system ( I don't think) with all brand new fluid.
Old 06-03-2015, 08:38 AM
Registered Bunny
polobunny's Avatar
Received 1,073 Likes on 892 Posts
My question to you is why you would do that though? There's technically the very faint risk of not pouring fast enough and running it dry. I don't really see the upside unless you're in a rush?
Old 06-03-2015, 09:29 AM
ggesq's Avatar
The discharge fluid transitions from old brown fluid to bright red in just a few seconds. It's obvious when you've gotten the old fluid out. Fastest most efficient way of getting 100% new fluid in
There's also the risk of overfilling it as well.
Mike Pilipenko
03-26-2024 09:21 PM
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
mellsonnj
09-24-2015 04:42 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: Transmission fluid via cooler hose
