L-139: DIY Replace Battery in Switchblade Key
Old 01-24-2010, 11:24 PM
csmeance's Avatar
Received 2,004 Likes on 1,424 Posts
If you have an Acura with a switchblade key, your battery is going to run out at some point so here is a DIY to help you take it apart and get it working again!
The one tool that will be vital is a precision 0 point Philips Screwdriver (available at any hardware store, it's a small 4 pointed screwdriver)
Here is a picture of the one I have and the Switchblade I'll be using:
Now on the bottom of the key under the chrome loop is the one screw you will need to remove to get access to the battery. Use the screwdriver and remove, use firm pressure and if it's really tight, first tighten then loosen to help break apart the loctite that is used to help hold the screw in tightly.
Removed:
Now you need to separate the remote from the key. Turn the key over so the Memory+ all the lettering is facing up. Press down on the chrome part and you will see the key split in 2 pieces along the center seam:
And here are your two pieces:
Now to separate the trim from the remote, press down on the trunk button or unlock button or lock button and it'll easily fall out from it's holder:
And this is what you have left:
Now this is the case that holds all the electronics for the remote and as well the battery:
This screw driver is pointing to the gap that you'll have to put your fingers in and pry apart to take the case apart. It's a pretty tight seal since the case is water-proof. (you'll see the gasket in the next few steps)
Use your thumbs!!! (don't mind the smudges, I did that to get rid of some ID info.
And now your remote is in 2 halves. In this photo the Negative side is facing up towards the camera (dotted side)
Pull up on the battery and put in a new one, this one reads Panasonic 1616 3V Japan:
The following 11 users liked this post by csmeance:
abrieluno (12-21-2012), bla8291 (01-29-2014), cyberbro (10-11-2014), eaglegreen48 (01-08-2013), Munk (11-18-2021), ninjai (11-14-2013), oneomar (02-25-2015), Rob Daddy (03-24-2016), TCTL_6MT_SSM (01-28-2014), vicfbls (01-24-2020), Wineman (03-02-2014) and 6 others liked this post. (Show less...)
Old 01-25-2010, 12:16 AM
NBP is a pain...
gotkilled's Avatar
thanks for the write up! i'm sure this will prove useful to members
RoloTL (10-21-2013)
Old 01-25-2010, 09:41 AM
2021 RDX A SPEC
Acura604's Avatar
Excellent. thanks very much.. i have to do this also.. anyone successfully source out this type of battery?
Old 01-25-2010, 09:43 AM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Old 01-25-2010, 01:40 PM
06 TL! / 05 R6
MightyTL's Avatar
Done!! Got my battery from Radio Shack...
Old 07-23-2010, 05:55 PM
ngstarr's Avatar
Switchblade key for 2004-2008 TL
Check out this site, does that mean I can get a swtichblade key for my '05 TL? Anyone tried this?
http://www.heeltoeauto.com/Fastline-...-pr-64771.html
Old 07-23-2010, 07:19 PM
dbqkqh's Avatar
Can we get an OEM DIY Battery Replacement?
I'm looking at the bottom of it and there seems to be an indent where it might be possible to apply pressure for the part to split in halves.
Not taking the risk/chance. It's not something vital where I need to change it now, but just for future reference so that I may avoid going to the dealership. But, if that is the only way, thanks for the help
Old 07-23-2010, 07:24 PM
05 NBP
images's Avatar
that little dip in the bottom of the key fob is the right spot, use a flat head, insert it and rock it side to side it'll pop open
after that its all self explanatory
Old 01-30-2011, 08:22 AM
ThugStunna's Avatar
Cr1616
Old 01-30-2011, 09:14 AM
boomersooner02000's Avatar
Yes, I've got one for my '06 and it worked perfectly.
Old 02-16-2012, 09:45 PM
You know him right?
some1's Avatar
Excellent post. I pulled out the controls part myself but didn't notice that it splits apart.
Pointer: Instead of your nails, try a coin. Very easy.
Old 06-20-2012, 03:06 PM
TripleLex's Avatar
Awesome write up!! Thanks!
Old 12-20-2012, 04:32 PM
TL-k100guy's Avatar
Great post
Tried this and it works like a champ. Thanks!
Some post on other threads stated, mistakenly or "just joking," that the key battery charges when you use the key in the ignition. The fob for my BMW 330i works that way. It tells you in the manual to use your backup key from time to time to keep it charged. I assumed it was the same with my TL, because the key that was dead was my backup, which I almost never use.
It does seem strange that the one I use all the time is fine, but the battery in the other one went dead. Something going on there.
Old 12-20-2012, 05:54 PM
NetoAzul's Avatar
sees complicated. but now i know how too
Old 12-20-2012, 08:46 PM
NavS's Avatar
My key battery died 6 times before I went and bought a replacement key... new(used) key price was pretty much the equivalent of the 6 batteries that I replaced. I can now take this damn thing apart all the way down to just the immobilizer...
Old 01-13-2013, 11:25 PM
sockr1's Avatar
Received 1,159 Likes on 909 Posts
main key still working but getting weaker (5 years) but the spare that I never used was dead....this thread was great and made the battery replacement so easy...2 min job
Old 01-28-2014, 05:01 PM
TCTL_6MT_SSM's Avatar
Thanks!!
Just wanted to thank you for the great DIY. Very helpful. My battery was finally going dead after 8 years of use and it was starting to get on my nerves having to hit the button so many times to get the doors to lock. Just replaced it tonight and it works great now. Funny how such little things can make you happy.
Also, I bought the battery on Amazon and got a pack of 5 for $6.99. I will keep one as a backup, but will never use the other 3. If anyone would like a battery, just hit me up with a PM with your address and I will send it out to you.
jkirsh27 (01-29-2014)
Old 01-28-2014, 05:05 PM
lilbatman636's Avatar
Awesome write up very helpful to me and also to everyone on here no more dead key fobs
Old 01-28-2014, 09:35 PM
bbergero1181's Avatar
any need to re-sync the fob with the car at all after replacing the battery? In the past when I asked the dealer about it they said they need both fobs so re sync to the car...were they BSing me?
Old 01-28-2014, 10:12 PM
vietxquangstah's Avatar
No need to resync the key here. I have a 08 base and replaced my battery in the key fob about a month ago. Everything still works just fine.
Old 01-29-2014, 11:42 AM
Thank you. Since no sync is required i will be changing the battery in the fobs since they are getting weak and their range is getting worse.
Old 01-29-2014, 10:15 PM
bla8291's Avatar
I was about to get a replacement fob and a spare... I thought it was the key going bad since it would only work completely randomly. This thread saved about $100 . Still gotta get that spare though.
Old 09-18-2014, 08:52 PM
6th Gear
djslim10's Avatar
Replaced battery but still dead
I replaced keyfob with new battery and verified that battery is installed correctly. However, the light doesn't lite up and I've had no luck with it unlocking/locking my car.
Any ideas?? Can the keyfob just die completely? 2007 with 107K miles.
My second keyfob works fine, but my wife keeps that. I may just have to switch with hers.
I even tried "reprogramming" it via the turn on then off method to no avail either.
Any advice is appreciated. Thanks.
Old 09-18-2014, 09:08 PM
csmeance's Avatar
make sure it is assembled properly and that the power pins on the circuit board are touching the battery.
Old 11-07-2019, 10:34 AM
MyGuti's Avatar
sorry to revive a old thread, but wondering if the 07/08 key fobs could run a 2025 battery instead of a 1616?
ordering a new battery for the wife's truck, comes in a pack of 5 2025's, figured i'd replace all keyfobs while im at it
Old 11-07-2019, 10:43 AM
Received 8,691 Likes on 6,705 Posts
Try it, it's a few mils thicker so might not fit but won't hurt to try
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
gemz_acura
4G TL Problems & Fixes
15
09-26-2015 06:12 PM
gqdabien
09-08-2015 11:41 PM
ellisd03tls
09-08-2015 04:17 PM
Quick Reply: L-139: DIY Replace Battery in Switchblade Key
