2007 & 2008 Acura TL Recall
Honda says it’s recalling nearly 53,000 Acura TL sedans in the U.S. to fix a problem with power steering hoses.
The hoses can deteriorate over time and leak fluid. That can cause the cars to lose power steering or even cause a fire.
The sedans are from the 2007 and 2008 model years. Honda says there have been no reported crashes, injuries or fires related to the problem.
Honda Motor Co. recalled 273,000 TLs in in 2008 for a similar problem. They were from the 2004 through 2008 model years.
Owners will get letters in mid-June telling them to take their cars to an Acura dealer.
Copyright 2012 The Associated Press. All rights reserved. This material may not be published, broadcast, rewritten or redistributed.
The following 4 users liked this post by TSX69:
I'm pretty sure my 06 had this. Not sure if it was a recall, but it was definitely a TSB for it. Mine was replaced about a year ago, it was leaking onto my engine, causing it to smoke at times.
BANNED
^it's been discussed ad nauseum...but the type-s models are NOT covered under the recall because of our VIN numbers or some BS like that. 07-08 type-s' SHOULD be covered, but depending on which month/year/VIN your car has...for some reason, it's not on the list.
luckilly it is a very simple repair and just requires a replacement o-ring.
BANNED
^yes but the hose starts to leak because of a faulty o-ring.
the replacement o-ring is different, and a different color. orange/red.
The following 3 users liked this post by SharksBreath:
NBP-UA6 (05-17-2012)
Head a da Family
Acura of Ramsey in NJ replaced the hose back in '08, but stupidly didn't do the O-Ring. That had to be done at another dealer.
Acura of Ramsey is CLEARLY the most incompetent dealer I've ever been to, and should be on the DEALERS TO AVOID list right up there with Paragon and Acura of Brooklyn.
Chapter Leader
(Northeast Florida)
(Northeast Florida)
Go to www.myacura.com and input your VIN.
when i bought my TL-S I have notice that the power steering was leaking so they took a look at it and replace the whole setup from pump to lines. The car felt like it was driving without power steering
When I logged in to myacura.com this morning, the web site did not list a Recall for my vehicle. So, I called American Honda Motor Co., Acura Client Relations and selected Option 4 for Recall Information. After providing my VIN, they confirmed my car is covered this time.
Phone: 800-382-2238
BrownBuck
Yah i went to myacura.com and logged in and clicked the recall link it shows you info specific to your car(depending on how much info u have put in vin # etc)
Says mine is not being recalled as of now.
http://owners.acura.com/Documentum/R...se_0000046.pdf
They did the recall in February when I had my brake fluid flushed.
Input my VIN and the recall doesn't apply to my '08. Still have yet to ever have a recall on it. Guess mine was made late enough that most of the problems were fixed on it.
AZ Community Team
Received 7,770 Likes
Bet it's for the Type-S's - which the dumb-asses excluded as a class in the BIG (273,000) recall.
I'll see if I can find the NHTSA docs and/or TSB's.
Thanks for the heads up.
AZ Community Team
No update at NHTSA. Yet.
http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm
No updates on the TSB page. Yet. https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
WDP Type-S sitting on air
i just got off the phone with honda. the lady said the myacura hasnt been fully updated yet so alot of people who are included in the recall will see that they arent included if the log in. if you call them they will tell you right away if you are or arent included. on myacura im not included but when i called i found out i am part of the recall.
AZ Community Team
This thread is a NEW recall on the same problem. Remains to be seen from documents (TSB and NHTSA), but as I mentioned before, I'm betting it's to included the previously excluded Type-S's.
BrownBuck
Yep call
(800) 382-2238 and hit option 4. Make sure you have your VIN# ready and they can tell you for sure if ur car is covered or not. Also, she told me to just wait until my notice comes in june to call the delar since they might not have all the parts yet.
I plan on calling them anyways today since i had few other things i wanted to ask them.
AZ Community Team
I've got the recall notice/press-release in my "Model Information --> Recalls" box at myacura.com.
2007 TL-S, 5AT. VIN in the 19UUA7 ..... x9000 range.
So, is this 'recall' NEW as of 5/17/2012?
Does that mean the recall they did back in Feb 2012 for my power steering hose doesn't address this recall?
I guess I need to give the dealer a call.......
AZ Community Team
A recall ALWAYS applies if you own the car, the repair has not been done previously AND you're in the VIN range.
(rebuild/salvage titles might be excluded; not sure.)
Edit:
The date on the notifiction in my myacura.com account is today's date.
For Immediate Release
Statement by Acura Regarding
Power Steering Hose Recall: 2007-2008 Acura TL
TORRANCE, Calif. – May 17, 2012 .....
Bearcat94 (05-17-2012)
MATT
just checked mine and it says i have no recall on my 08 type S....just called and confirmed that mine is included in the recall...looks like ill be taking it in
BANNED
this thing is ridiculous.
you got a type-s? what year? 07 and the VIN matches...you're in luck! you are covered!
oh...you have an 08 type-s? sorry...this doesn't apply to you. better luck next time.
