Over The Air (OTA) Software Update D.1.2.1
Old 11-08-2019, 03:04 PM
  #161
Expanse me
Funz51's Avatar
Originally Posted by djdaddykool
Had not tried that yet, the 2016 would not play FLAC. So it does work?
BTW I have seen that issue you reported as well.
yes, see the user's manual.
Old 11-08-2019, 04:03 PM
  #162
catalytic_ca's Avatar
Yay! Installed it this morning. AA is here finally! Hallelujah!
But unfortunately not absolute positioning true touch interface for AA. I thought support for the rare AP TTI was responsible for the delay... that Google had to program the code to make it work from scratch.
Using a regular trackpad sucks and makes me appreciate the AP TTI even more.
Ah well, I guess I shouldn't be ungrateful. Hopefully they will figure out how to support AP TTI in the next update.
Google Maps is washed out for me too.
Old 11-08-2019, 07:54 PM
  #163
JB in AZ's Avatar
Go into settings and turn on "Satellite" mode. MUCH easier to see
catalytic_ca (11-09-2019)
Old 11-08-2019, 08:08 PM
  #164
rdxny's Avatar
Mostly AA working for me with a Samsung s9+
What isn't: Waze ( I now run Waze on the phone, and Google maps on the RDX screen. I like the warnings Waze gives that Google does not, and so far I have found Waze's traffic info and predictions more accurate, by a little. I know they share data, but there are differences in route planning, eta, warnings, etc). But the RDX screen display is way better than looking at the phone. Hopefully, they will turn on Waze in the RDX screen
I seem to get disconnects, maybe once or twice a trip, when AA loses connection with the phone, and I get "AA unavailable". You then lose Google navigating, music (Spotify), etc. Unplugging the cable and re connecting fixes it, but you have to restart all. My cable is good, and it disconnects without touching anything, but I suppose the random disconnects could be cable related. I'll try another soon.
Took me a bit to realize that most settings for AA apps need to be input on the phone, not the RDX. I was looking for ways to save favorites in apps, but they get saved on the phone. Learning curve...
Old 11-09-2019, 08:11 AM
  #165
DrWoo's Avatar
Originally Posted by Funz51
Yup
Hi res flac
And not just hi res, but 5.1 surround. And it sounds amazing.
The following 3 users liked this post by DrWoo:
Funz51 (11-09-2019), oblio98 (11-09-2019), Padre Dave (11-10-2019)
Old 11-09-2019, 08:34 AM
  #166
djdaddykool's Avatar
I posted a list of recommended cables. I had continuous disconnects and purchased the Anker cable and all is good now.
On the Play store there is a section for supported AA apps. I did find some posts on changing default from Google maps to Waze.
I will post that link later
Old 11-09-2019, 04:43 PM
  #167
billyt1963's Avatar
I have an iPhone, so can't try this out.
Someone posted on YouTube how to get Waze on Android Auto on the RDX.
Hope it helps.
Billy
The following 6 users liked this post by billyt1963:
catalytic_ca (11-09-2019), Dadeda (11-11-2019), JB in AZ (11-09-2019), RDX-Rick (11-09-2019), rdxny (11-09-2019), TucsonST (12-06-2019) and 1 others liked this post. (Show less...)
Old 11-09-2019, 05:00 PM
  #168
This might be true for older Android versions, but for Android10 there is no separate app that you can launch that loads with the settings menu as shown in this video. Therefore you cannot tap to get into developer mode.
I'm on Android 10 PixelXL2
Old 11-09-2019, 05:34 PM
  #169
rdxny's Avatar
I tried this on my Samsung s9+ (running android 9) and.. it works! Haven't had time to test the whole integration, but it runs and seems to work just fine.. nice work!
billyt1963 (11-09-2019)
Old 11-09-2019, 05:40 PM
  #170
Midwestuser1's Avatar
I highly doubt it’s the cable in most cases. When issues are “intermittent” in nature that almost always points to software being the issue. Hardware or physical connections issues are usually much more consistent in their behavior.
Old 11-09-2019, 07:12 PM
  #171
RDX-Rick's Avatar
Hope it helps.
Billy
I am running Android 7 and it worked for me. Thanks Billy.
Old 11-09-2019, 07:27 PM
  #172
pbsredrdx's Avatar
Have you tried this?
https://play.google.com/store/apps/d...ad.phonescreen
Also, you can try to launch it in the Settings menu of the phone:
Settings --> Apps --> Android Auto --> Open
Old 11-09-2019, 08:48 PM
  #173
JB in AZ's Avatar
https://www.youtube.com/watch?v=WrHd11x8ehE
Hope it helps.
Billy
So the question I have is .....why didn't Acura enable Waze if it works?
Old 11-09-2019, 09:08 PM
  #174
RDX-Rick's Avatar
I only got it working by changing a hidden setting within the Android Auto app on my phone. Afterwards Waze became available on the "Acura" . I can't blame Acura for Waze not working if Google was restricting it in their app.
Old 11-09-2019, 09:31 PM
  #175
JB in AZ's Avatar
Ah, good point.
Old 11-09-2019, 10:34 PM
  #176
Padre Dave's Avatar
Originally Posted by chappyja
Just tried to manually pull it from wi-fi in my garage and it just says "there are no updates available..."
My car gives me the usual System Updates false alarm, but I have received no notifications about this. If you check it will it come up without a message to the car?
Old 11-10-2019, 08:36 AM
  #177
Goalie127r's Avatar
Changing cable absolutely worked for me.
Old 11-10-2019, 11:27 AM
  #178
Cuzz's Avatar
What brand cable did you end up going with?
Old 11-10-2019, 12:24 PM
  #179
Alright I’ll eat some crow. I was using a brand new Monoprice Lightning cable and was getting the random crashes of CarPlay. I switched to an Apple branded cable that I knew was fairly new and it worked without crashing so far. Frustrating that a brand new cable from Monoprice couldn’t perform properly (it was a 4 ft. Cable so not overly long).
jonarogers (11-11-2019)
Old 11-10-2019, 12:29 PM
  #180
As I stated earlier, on Android 10, you must enable developer mode from the Play store. Once in developer mode you can change the mode to developer and then Waze will show up OK.
There are a bunch of other settings in developer mode.
Old 11-10-2019, 01:04 PM
  #181
How I got there with a Pixel2XL.
1. Settings
2. Apps & Notifications
3. Android Auto
4.Additional Settings in app
5 Triple dots in upper right corner. Select Developer settings(once enabled).
6 Application mode. select Developer.
7 Done.
Old 11-10-2019, 02:17 PM
  #182
7th Gear
rpgman's Avatar
Ok I'm not getting this...to get Waze on the RDX screen.
I enabled developer mode in the play store..now what?
I'm on a galaxy 10÷.
Old 11-10-2019, 03:02 PM
  #183
reboot the phone
Old 11-10-2019, 04:18 PM
  #184
Well I spoke to soon as it crashed again with the Apple branded cable as well. Can’t seem to see any pattern on when it crashes as I won’t be touching the phone and I just having it running the navigation via the Apple Maps. Still looks to be software glitches!
Old 11-10-2019, 04:33 PM
  #185
'20 RDX Adv, built 11/19
MrmissmyTLX's Avatar
A couple of quick questions for you Midwestuser1... 1) Do you have a 2019 or a 2020 model? 2) Did the maps crash or or CarPlay as a whole?
Old 11-10-2019, 04:36 PM
  #186
I have 2019 Aspec. When the maps crash the Carplay is “greyed out” on the home screen of the infotainment system. Thus all things CarPlay crash including the music if I was playing any.
Also things I’ve already done/tried: Remove my IPhone via Bluetooth and repaired it, removed CarPlay in the phone settings so it had to re-establish a fresh connection with the car.
The only logical conclusion I can draw is some sort of software glitch.
MrmissmyTLX (11-10-2019)
Old 11-10-2019, 04:46 PM
  #187
Any 2020 RDX owners having CarPlay issues/crashes AFTER installing the d.1.2.1 update? I am asking because I am trying to do some research before I possibly buy. Anything else I should look for or be concerned about while test driving? I've test driven the 2020 RDX Advance 2x do far at 2 different dealers within the past month.
Old 11-10-2019, 05:16 PM
  #188
Cuzz's Avatar
You should ask one of them to let you have an extended overnight test drive. They may give you one of their loaners from the service department. It will probably be a Tech package, but will give you more time to play with it.
Old 11-10-2019, 05:26 PM
  #189
7th Gear
rpgman's Avatar
reboot the phone
Still not seeing additional settings when I go to settings then apps then Android Auto
Old 11-10-2019, 06:07 PM
  #190
Madd Dog's Avatar
Received 1,025 Likes on 715 Posts
No crashes yet. I use a very short cable, and do not use Carplay much at all. But when I do, I have not had crashes. But I do not stress the system.
Old 11-10-2019, 06:12 PM
  #191
Default
DarkNinja75's Avatar
My other car is a 2017 Chevy which has had AA since 2017. A lot of the problems being described here I also get in my Chevy. I get random errors, greyed out AA, and have to restart my phone usually once every 3 or 4 trips to get it to work.
Old 11-10-2019, 07:24 PM
  #192
Settings
Apps
Android auto
Advanced settings in the app
Right at the end before the version. You should see additional settings in the app.
Old 11-10-2019, 07:45 PM
  #193
7th Gear
rpgman's Avatar
Settings
Apps
Android auto
Yea when I go into settings/apps/Android Auto I don't see Advanced at all.
Old 11-10-2019, 07:47 PM
  #194
Just completed an interesting test with CarPlay. I let the car fully boot up before connecting my IPhone which I had put directions in Apple Maps for my test. I started driving and within a few miles the CarPlay had crashed. I tried unplugging/plugging back in the Lightning cable from the phone and the USB slot in the RDX and neither would revive the Carplay connection. Then with the Lightning cable plugged into the phone and the car I powered off my IPhone and when I powered it back on the Carplay connection became live again. I did NOT need to pull over and restart the car to get the Carplay to be active again.
This test leads me to think that the Carplay crash happened within the phone versus the car as rebooting the phone re-established a live Carplay connection again. After this rebooting of my IPhone I continued using the Apple Maps via Carplay and it did NOT crash again for over 20 minutes of driving. Not sure what this examples shows but at least it is some additional data.
Old 11-10-2019, 08:19 PM
  #195
Madd Dog's Avatar
Hmmmm. Maybe background refresh setting or something?
Old 11-10-2019, 08:35 PM
  #196
Not sure how as after the phone reboot I did not change any settings. ???? (Software glitches can be quite perplexing)
Old 11-11-2019, 09:35 AM
  #197
EFR
EFR's Avatar
What I-phone do you have?
Old 11-11-2019, 10:26 AM
  #198
I have the XS Max 256GB model.
Old 11-11-2019, 10:53 AM
  #199
jonarogers's Avatar
Since the 1.2.1 update I have not had issues. I was one of the more... vocal critics of this car for the past year I've had it too. Been in contact with Acura and the dealer for a while. Even started down the lemon law route (and got a nasty note back from Acura!) I got the RDX because at the time the competitor cars I was looking at did not offer CarPlay and I am big tech guy (Q3, Lexux NX) but I have to say, now that CarPlay works my opinion has completely changed. The engine, comfort, style, Honda reliability.. and now finally the tech works!
pnoi521 (11-11-2019)
Old 11-11-2019, 12:12 PM
  #200
EFR
EFR's Avatar
Thanks. I am just curious...wondering if some of the issues sometimes aren't related to an older phone (mine is a 6S+...so pretty old.) I have had issues (not since the update, at least yet) where I had to disconnect and restart my phone to get things working again.
Quick Reply: Over The Air (OTA) Software Update D.1.2.1
