Windows update Fails
Old Jul 3, 2005 | 07:30 AM
  #41
Whiskers's Avatar
Go Giants
Originally Posted by zamo
with intel or IBM chips?
Yes, why?
Old Jul 3, 2005 | 10:15 AM
  #42
Vector02's Avatar
Kinda a pain, but you could always boot from your xp cd and do a repair. Re-activate the repair copy and do SP2 and all updates again.
Old Jul 3, 2005 | 12:16 PM
  #43
ghost_masterCL's Avatar
well, you are technically alwasy supposed to disable all you're other programs unless it says "you may continue doing other tasks while this is installing" or whatever. Otherwise, I'd go with what vector said, try a repair, and if that doesnt'w work then just say screw it till the next update comes out.
Old Jul 3, 2005 | 12:20 PM
  #44
Shoofin's Avatar
I had the same problem with one of the updates....I still can't get the update to install...
Security Update for Windows XP (KB890175) Is the on I'm having problems with..
"Security Update for Windows XP (KB890175)
A security issue has been identified that could allow an attacker to compromise your Windows-based system and gain control over it. You can help protect your computer by installing this update from Microsoft. After you install this item, you may have to restart your computer."
I did successfully update the comp with the other updates, including the one you're having problems with. But now if I go in to check for any updates I need it says there are none..
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
thegipper
Sep 28, 2015 01:01 PM
