Windows Server Admins chime in
Old Aug 9, 2005 | 11:33 AM
zamo's Avatar
Houses Won't Depreciate?
Ok, this issue brought down the acces to the server until i found out what was causing it.
SERVER has 2 IP addresses, one for LAN, and one for PPP (for VPN dial in):
Code:
Z:\>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : SERVER
   Primary Dns Suffix  . . . . . . . : domain.com
   Node Type . . . . . . . . . . . . : Unknown
   IP Routing Enabled. . . . . . . . : Yes
   WINS Proxy Enabled. . . . . . . . : Yes
   DNS Suffix Search List. . . . . . : domain.com
PPP adapter RAS Server (Dial In) Interface:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
   Physical Address. . . . . . . . . : 00-53-46-00-00-00
   DHCP Enabled. . . . . . . . . . . : No
   IP Address. . . . . . . . . . . . : 192.168.1.29
   Subnet Mask . . . . . . . . . . . : 255.255.255.255
   Default Gateway . . . . . . . . . :
Ethernet adapter LAN 1:
   Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet
   Physical Address. . . . . . . . . : 00-0F-1F-6F-19-4A
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 192.168.1.1
   DNS Servers . . . . . . . . . . . : 192.168.1.2
                                       192.168.1.1
The issue comes out when making a forward lookup:
Code:
Z:\>nslookup server
Server:  UnKnown
Address:  192.168.1.2
Addresses:  192.168.1.29, 192.168.1.2
it is choosing the ip assigned for PPP and not for LAN 1 (which it should be).
PPP is enabled via Routing and Remote Access and I do not see an option to STOP registering DNS for that IP.
all clients should only resolve to 192.168.1.2.
How can I fix that? I delete from the DNS server but it reapears.
Old Aug 9, 2005 | 11:45 AM
doopstr's Avatar
Open the properties of the PPP NIC. Then TCP/IP.
Hit the Advanced button, switch the the DNS tab. Turn off the option to automatically register in DNS.
Also,
What is up with this?
192.168.1.1
What type of device is 192.168.1.1? Is it a windows machine or a hardware router?
If you are running active directory only your domain controller should be listed as a DNS server.
So is if 192.168.1.2 is a domain controller and 192.168.1.1 is some kind of router, remove 192.168.1.1, from your list of DNS servers.
Old Aug 9, 2005 | 11:52 AM
zamo's Avatar
ok, 192.168.1.1 is the default gateway and secondary DNS server (for redundancy purposes). It is a router device.
192.168.1.2 is the primary domain controller (there is a mirror of it in another ip), and is the one resolving the 2 ips for "server".
Now the issue is; there is no PPP adapter on Network Connections. PPP is created by RAS and I cannot see the option to automatically register in DNS.
Old Aug 9, 2005 | 12:36 PM
Whiskers's Avatar
Go Giants
You could remove the RAS service if you don't need it.
Old Aug 9, 2005 | 12:53 PM
Billiam's Avatar
Big Block go VROOOM!
Common practice but not always true. I'd bet there are plenty of shops that don't run DNS on their DC's. Hell, we don't even use M$ DNS. We're all Active Directory and BIND 9.x works fine for us.
Old Aug 9, 2005 | 12:57 PM
doopstr's Avatar
Scope this article, it appears to be your setup
http://support.microsoft.com/?kbid=289735
Oh, and thank you for giving me something to think about today. My brain is going stale.
Old Aug 9, 2005 | 01:00 PM
zamo's Avatar
Thanks doopstr, but it applies to
• Microsoft Windows 2000 Server
• Microsoft Windows 2000 Advanced Server
I also found this article
http://support.microsoft.com/default...b;en-us;832478
Old Aug 9, 2005 | 01:01 PM
zamo's Avatar
RRAS is absolutely required unfortunately
Old Aug 9, 2005 | 02:15 PM
zamo's Avatar
SP1 did not help. As soon as a PPP connection is stablished, the A record is added to the DNS and fucks up the whole forward DNS lookup from the inside workstations. This has never happened tho.
I will need to disables RRAS and run it on another box.
Old Aug 9, 2005 | 02:37 PM
doopstr's Avatar
In regards to the article I posted. Did you look to see if those settings exist in 2003?
Old Aug 9, 2005 | 03:25 PM
zamo's Avatar
Seems that you are right on track. I am a DBA, so I deal vaguely as an admin with windows and linux boxes.
Anyways this might do the trick:
1. Start DNS Manager.
2. Right-click the computer name, and then click Properties.
3. Click the Interfaces tab, and then click Only the following IP addresses.
4. Remove any Routing and Remote Access IP addresses that are listed.
Thanks doopstr
Old Aug 9, 2005 | 04:21 PM
zamo's Avatar
nslookup server
nslookup server.domain.com
they both bring now 1 ip and that is the correct one
The problem now
When I try to access to shared folders from windows explorer
\\server - seems to resolve to the VPN IP although it is not in the DNS forward lookup. I CANT see anything.
\\server.domain.com - works fine
the specific dns suffix on the local machine is domain.com
there are no WINS server.
What can be happening?
Old Aug 9, 2005 | 04:51 PM
doopstr's Avatar
There is probably some netbios issue.
Download NBTScan http://www.inetcat.org/software/nbtscan1_5_1.zip
Expand it into a folder on your harddrive.
From a commnd line run nbtscan -r 192.168.1.0/24
That will scan your subnet for netbios responses. See what IP your server is returning and see if it is returning more than one.
Old Aug 9, 2005 | 05:19 PM
zamo's Avatar
Indeed
How can I delete it?
Old Aug 9, 2005 | 05:58 PM
doopstr's Avatar
I reread that article I posted. I think this is going to be a problem, mainly because that PPP adapter is created on the fly when the first user connects. The article really frowns upon multihomed domain controllers, probably because of this bug they don't feel like fixing.
How many users are we talking about?
You can either populate the LMHOST file on every workstation with the server/ip or put RAS on another machine. Putting up a second machine would technically be the cleaner solution.
You really don't need much horse power to run a dial-in ras. Any hunk of junk will do.
Old Aug 9, 2005 | 06:18 PM
Whiskers's Avatar
Go Giants
Isnt there a way to assign it another A record in DNS.
Old Aug 9, 2005 | 06:33 PM
zamo's Avatar
That will be my solution. I tried enabling RRAS in another machine but it hosed the system for some reason. I connect to these machines remotely via VPN, so if one of them freezes I am stuck (unless someone helps me on-site).
The weird issue is that the solution has been running for a while and today started throwing the incorrect IP.
So to wrap it up, no way I can delete the WINS entry for PPP ?
Old Aug 9, 2005 | 06:34 PM
zamo's Avatar
DNS is all fixed. The issue is now WINS resolution.
Oh and VPN does not hold more than 2 clients at most.
Old Aug 10, 2005 | 08:42 AM
doopstr's Avatar
From the article...
RESOLUTION
NOTE: If you run Routing and Remote Access on a domain controller that owns the operations master role, a multi-homed master browser is created. It is recommended that you install Routing and Remote Access on another computer for full browsing capabilities. It is also recommended that the domain controller, which is the multi-homed master browser, has only one interface. For additional information, click the article number below to view the article in the Microsoft Knowledge Base:
In other words, "It's broke and we aren't fixing it"
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
