IT: Weird Cisco IOS Bug??
Old Jun 21, 2011 | 10:42 AM
thunder04's Avatar
Sweet!
I'm configuring a switch. It's a Cisco 3560G running IOS 12.2(55)SE3 (latest ver. for this switch) with IP services.
I need to set some things on an interface. In this particular case, it's a route-map to redirect web traffic to a content filter. I've done this a million times on other switches/routers, so I know what I'm doing is correct.
I type in the command to apply the route map to the interface, and it accepts it. No complaints.
I go to browse to a site that's blocked, and it loads.
I show the running config, and what I did to the interface didn't apply.
So, I issue the command again. No complaints.
I show the running config again, and it's still not there?!
Huh?!
Has anyone encountered this? What gives?
Old Jun 21, 2011 | 10:48 AM
Ken1997TL's Avatar
Are you using Cisco's network assistant to do this?
Old Jun 21, 2011 | 10:49 AM
thunder04's Avatar
Sweet!
Nope...all CLI via telnet.
Old Jun 21, 2011 | 10:57 AM
thunder04's Avatar
Sweet!
Can a mod edit the title to include "Cisco" before IOS? I always forget that Apple took the acronym...
Old Jun 21, 2011 | 11:09 AM
Ken1997TL's Avatar
Done
Old Jun 21, 2011 | 11:10 AM
thunder04's Avatar
Sweet!
^ Thanks!
(is it just me, or did the "Thanks" button disappear?)
Old Jun 21, 2011 | 11:14 AM
thunder04's Avatar
Sweet!
Hmm, I dug around a little more, and it looks like the command's error is only displayed via the console. When doing "terminal monitor" I see the error...
Code:
Jun 21 16:13:43.378: %PLATFORM_PBR-4-SDM_MISMATCH: PBR requires sdm template routing
Hmm...
Old Jun 21, 2011 | 11:19 AM
thunder04's Avatar
Sweet!
AHA!
http://www.cisco.com/en/US/docs/swit...html#wp1055603
Answered my own question .
Old Jun 21, 2011 | 11:38 AM
TeknoKing's Avatar
Since we are on the Cisco topic, has anyone had an encounter with IPS? (Intrusion Prevention System or as I call it, POS. It locks half of bandwidth when enabled, but when disabled FTP is then blocked, the DNS is not resolving, can't connect passive or active or anything.
I hate these effen routers. (RVS4000)
Old Jun 21, 2011 | 01:34 PM
thunder04's Avatar
Sweet!
^ Unfortunately, I have not.
Skirmich
Oct 1, 2015 12:59 PM
kb1rl
Sep 30, 2015 10:17 AM
giovane
Sep 26, 2015 10:59 AM
ROWDY621
Sep 22, 2015 11:02 PM
