IT: Weird Cisco IOS Bug??
I'm configuring a switch. It's a Cisco 3560G running IOS 12.2(55)SE3 (latest ver. for this switch) with IP services.
I need to set some things on an interface. In this particular case, it's a route-map to redirect web traffic to a content filter. I've done this a million times on other switches/routers, so I know what I'm doing is correct.
I type in the command to apply the route map to the interface, and it accepts it. No complaints.
I go to browse to a site that's blocked, and it loads.
I show the running config, and what I did to the interface didn't apply.
So, I issue the command again. No complaints.
I show the running config again, and it's still not there?!
Huh?!
Has anyone encountered this? What gives?
Huh?!
Received 2,329 Likes
Are you using Cisco's network assistant to do this?
Done
Since we are on the Cisco topic, has anyone had an encounter with IPS? (Intrusion Prevention System or as I call it, POS. It locks half of bandwidth when enabled, but when disabled FTP is then blocked, the DNS is not resolving, can't connect passive or active or anything.
I hate these effen routers. (RVS4000)
kb1rl
09-30-2015 10:17 AM
giovane
09-26-2015 10:59 AM
