Video issues, insight needed
Old Mar 13, 2013 | 09:52 PM
jupitersolo's Avatar
nnInn
Thanks in advance
I've been playing SimCity lately and monitor goes into power saving mode, was set at 20 minutes. I have turned it off and still get it, but longer than 20 minutes, that was set. When it goes into power saving mode, I cannot wake it with keyboard or mouse.
I have gotten this problem before once or twice per month, when I have left the computer on overnight, which I pretty much do every night. It was always on the 20 minutes shut-off.
I have to do a power switch reboot.
I have updated to latest drivers and software for GeForce GTS260, used a different cable, and swapped monitors, both Dells.
Time for a new video card??
Again Thanks
Old Mar 13, 2013 | 11:40 PM
Ken1997TL's Avatar
Two more things to check:
Control Panel -> Power Options
Change plan settings -> Change Advanced Power Settings
Check under Display, make sure it's set to Never.
Also, go under your monitor's physical control menu, make sure any sort of 'eco' settings or power saving modes are OFF.
Old Mar 14, 2013 | 09:00 AM
nnInn
That was what I did to turn off the 20 minutes..,
So it's a new video card?
Old Mar 14, 2013 | 02:24 PM
Ken1997TL's Avatar
It shouldn't require that. It's gotta be a setting that's being overlooked.
Old Mar 14, 2013 | 09:37 PM
nnInn
I dug deeper into the "Change Advanced Power Settings" harddrive was set to shut down at 20 minutes. I have SSD. I played SimCity for about an hour when I set it to never. Couldn't play longer that, at that time.
I did get a new video card though, GTX 650. It was needed, I was being slowed down with the 260 when performing certain Photoshop tasks.
Thanks for the guidance.
Old Mar 15, 2013 | 04:32 AM
Whiskers's Avatar
Go Giants
Reinstall the video driver first.
Old Mar 15, 2013 | 04:45 AM
nnInn
I updated to the latest drivers before posting this thread.
Old Mar 15, 2013 | 06:44 AM
Whiskers's Avatar
Go Giants
showoff
Old Mar 18, 2013 | 09:23 AM
madrussian190's Avatar
I would ditch the 260 and get the 650ti. That is a very nice card.
Old Mar 18, 2013 | 09:30 AM
nnInn
Well, on Saturday it wouldn't run for more than 15 minutes, timed it the second time, was about 11 minutes. Last night played over an hour w/o issue.
I order a GTX 650, which is sitting here to be swapped out.
Old Mar 18, 2013 | 09:40 AM
Could be a number of issues... but as long as you have confirmed that it is not due to the "Power Options" it might be pointing to your card.
When you swap out the card, completely remove the drivers from your system and reinstall them fresh when you put in the new card.
Old Mar 20, 2013 | 02:55 PM
nnInn
The new video card did the trick!
Old Mar 20, 2013 | 02:57 PM
Whiskers's Avatar
Go Giants
I knew it.
Old Mar 20, 2013 | 04:12 PM
nnInn
Thanks, do you know anything about the latest Window update that is disabling Aero?
Old Mar 20, 2013 | 04:15 PM
Whiskers's Avatar
Go Giants
No, but its either the video or monitor driver or you have a logmein installed.
Old Mar 20, 2013 | 06:44 PM
nnInn
No logmein, could be drivers. I removed update.
Old Mar 21, 2013 | 05:30 AM
Whiskers's Avatar
Go Giants
Old Mar 22, 2013 | 09:17 AM
Removing Aero? Hmmmm... First I'm hearing of it... Usually we don't enable it
mada51589
Jan 9, 2025 04:40 PM
kuzdu
Sep 10, 2015 08:42 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
NSolace
Sep 3, 2015 08:14 PM
