Network Rack Experts - Patch Panels
Is it necessary to put a patch panel in front of the switch in a rack? I'm trying to figure out what the benefit to having one is... Why not just plug in directly to the switch?
Seems like an awful lot of cabling work for benefits that I'm not able to figure out.
BTW, I plan on putting in a 2 or 4 post rack in my home, hence why I'm asking.
The only benefit is that if something happens to the cable between the patch panel and the switch it is easy to replace that cable. The other benefit is it will look more professional. You won't have cables hanging all over the place.
In theory, I could load up the 24 port switch I picked up.
But I still don't get it. Cleaner, OK. But the spaghetti still gets plugged into the patch panel, then the individual wires are connected to the back of the patch panel, to the switch. Seems like an awful like of wiring work, for what???
I doubt this is something you'd need in your home.. You need a 24 port in your home???
It is really intended for mixed-use/mixed-technologies. The idea is that in a enterprise environment you may have separate switches for separate purposes, one for voip, one for private, one for public, etc. You would then patch the correct port to the correct infrastructure switch.
Certainly for home use it is overkill, but it does look good.
My parents have a patch in their house because each room has two ports. The phone system that came with the house is basically a business system and uses rj45 connections for the phones as well so by having the patch we can easily switch which port is network and which is phone in the rooms. We didn't chose this system it was in the house when my parents bought it.
So I have cat 6 coming into a closet... I run those cables to the patch panel. And that sits right in front of the switch, correct? Then I run a small cat 6 from the back of the patch panel to the switch?
Why not just go directly to the switch? What am I missing?
The cat6 comes into your closet and runs into the back of the patch panel and is hardwired to each respective port. Then you simply patch each port over to your switch with a short cable.
It looks nice and is a must in a enterprise infrastructure since you usually have more than one switch and function so you may move patches from time to time. In your environment it isnt a must.
For you, it wold mainly be a neatness thing. No other real benefit unless you plan on changing things around frequently, in which case it makes things easier.
EDIT: What JLat said...
I may do it. I absolutely hate doing network wiring, though... The connectors drive me ape shit.
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
