Is my desktop computer dying? :D
Old May 19, 2014 | 12:54 PM
JS + XES's Avatar
I drive a Subata.
I think my desktop computer is slowly dying.
Whenever I play Diablo3, the screen freezes in about 10 minutes and I have to manual press and hold power button to restart.
Ctrl+Alt+Delete function doesn't even work.
Sometimes, it gives me a blue screen and restarts itself.
What is a little odd is that it doesn't give me any problems for other uses at all.
The desktop is about 3-4 yrs old.
It's probably time to get a new one, right?
Old May 19, 2014 | 01:14 PM
AZuser's Avatar
_
GPU going bad? Power supply going bad? Overheating? Is it clean inside (i.e. no dust bunnies clogging up fans?)?
If you don't have problems with normal non-gaming use, then no, it's not dying. Need to do some diagnostics to see what's wrong.
JS + XES's Avatar
I drive a Subata.
How can I check which one is going bad?
I haven't opened up the computer for like 6 months I think.
Old May 19, 2014 | 01:15 PM
JS + XES's Avatar
I drive a Subata.
Whenever it freezes, the computer makes pretty loud noise.
Old May 19, 2014 | 01:21 PM
TeknoKing's Avatar
loud noise? only your hard drive or a bad fan can make a noise. Open it up and turn it on, pay attention to all the fans and try to isolate that noise.
Is it a clanking noise?
Old May 19, 2014 | 01:25 PM
JS + XES's Avatar
I drive a Subata.
I will open it up and listen to it to find which one is going bad.
It's like something is spinning very fast when it freezes.
Old May 19, 2014 | 01:51 PM
AZuser's Avatar
_
Since you have dogs, one or more of the cooling fans (case fan, CPU fan, GPU fan, power supply fan) could be clogged up. Might need a can or two of compressed air to blow all the crap out.
I do a cleaning 2x a year: once right before summer to reduce the likelihood of it overheating and again about 6 months later.
Old May 19, 2014 | 01:54 PM
JS + XES's Avatar
I drive a Subata.
I just got a compressed air can. Will try that after work!
Thank you! I'll report back after.
Old May 19, 2014 | 02:19 PM
Anachostic's Avatar
The answer to this question is always yes. Same reasoning for cars, beers and girlfriends.
Old May 19, 2014 | 04:25 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Old May 19, 2014 | 06:54 PM
#1 STUNNA's Avatar
Sanest Florida Man
Download bluescreenview by clicking this link
http://www.nirsoft.net/utils/bluescreenview-x64.zip
extract it and run that program. it will usually tell you the cause of your BSOD whether it's a gpu or something else. Run that and tell use what the error code is and which file was involved. Then we can be of more help
Old May 19, 2014 | 09:21 PM
ChodTheWacko's Avatar
Moderator Alumnus
It's most likely your video card's fan is dead/unseated/covered with dust, causing it to overheat.
This causes strange things, crashes the OS, and can often lead to the 'loud buzz'.
This has happened to me many, many times. I had to underclock my previous video card or it would do this every single time I played a game.
- Frank
Old Jun 4, 2014 | 04:43 PM
JS + XES's Avatar
I drive a Subata.
Forgot to update...
So, I had opened up the desktop a week ago.
There were some very large dust ball looking shits everywhere.
I vacuumed all up and now the comp is not giving me any error.
Guess it was the dust!
Old Jun 4, 2014 | 04:57 PM
Ken1997TL's Avatar
Dust will do that! Every year I completely take my desktop computer apart, clean everything and reassemble
Old Jun 26, 2014 | 10:17 AM
JS + XES's Avatar
I drive a Subata.
It started doing it again.. Freezing up.. Occasional blue screen..
I downloaded that blue screen reader and got this..
Old Jun 30, 2014 | 11:07 AM
JS + XES's Avatar
I drive a Subata.
Can someone take a look at the pic please?
Is it the graphic card or other stuff?
Thank you guys.
Old Jun 30, 2014 | 11:12 AM
maharajamd's Avatar
http://www.sevenforums.com/bsod-help...-exe-bsod.html
MetalGearTypeS
Aug 29, 2016 08:28 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
AcuraKidd
Sep 25, 2015 11:18 PM
