MS Excel Help
I have 2 spread sheets i need to put on one page. The cells that contain the info are different sizes. If i put spread sheet 1 on first all the info on spread sheet 2 is compacted and not readable.
Follow me?
Follow me?
I can't see the way you have it setup not working.. Unless you have the whole page setup as one font size, font etc... Try and clear a few rows and set them up the way you want it then copy and paste into those cells..
Follow me?
Follow me?
If viewing, just copy and paste and then select the cells for the 2nd spreadsheet and enlarge the font size.
If printing you have to use the Page set-up, Print Preview option to change the margins.
Ok, this is what he is saying. The cols/rows of the first sheet are smaller than that of the second sheet. So, when he pastes the second sheet on the first sheet, the first sheet will show huge spaces or widths, while the second looks normal.
The best solution that I have is to wrap text the cells and fool around with the size.
What phipark said is whats happening. I figured out a way to print it but it looks like shit.
I have 2 spread sheets with different sized cells. When i put them on the same sheet the sizes get all screwed up.
I understand.. Sometimes you have to weigh the options between using Word and Excel.. Excel you can't individually size each block/cell.. It must be the whole rows/row.. But sometimes you can merge cells together to make it fit a little better.. If it's nothing personal or confidential you can send me the file and I can try and dress it up for you..
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
