MS Excel Help
Old Feb 3, 2004 | 05:41 PM
ComptechType-S's Avatar
Time to POWER UP!!
MS Excel Help
How do i put two spread sheets on the same page when the cells are different size?
Crap has been kicking my butt for over an hour
Old Feb 3, 2004 | 05:45 PM
Jonesi's Avatar
Still not sure what you want to do.. You can copy and paste it below the first set of rows you have..
Old Feb 3, 2004 | 05:58 PM
Time to POWER UP!!
I have 2 spread sheets i need to put on one page. The cells that contain the info are different sizes. If i put spread sheet 1 on first all the info on spread sheet 2 is compacted and not readable.
Follow me?
Old Feb 3, 2004 | 06:02 PM
Jonesi's Avatar
Are you using the copy & paste or are you just trying to merge the two sheets ?
Old Feb 3, 2004 | 06:13 PM
Time to POWER UP!!
Copy and paste. How do you merge?
Old Feb 3, 2004 | 06:23 PM
Jonesi's Avatar
I can't see the way you have it setup not working.. Unless you have the whole page setup as one font size, font etc... Try and clear a few rows and set them up the way you want it then copy and paste into those cells..
Old Feb 4, 2004 | 12:45 PM
melo72's Avatar
Follow me?
Not readable when? When you print it out or when you view it?
If viewing, just copy and paste and then select the cells for the 2nd spreadsheet and enlarge the font size.
If printing you have to use the Page set-up, Print Preview option to change the margins.
Old Feb 4, 2004 | 01:18 PM
ViperrepiV's Avatar
sup
you can select format >>cols>>auto fit and you can do the same for the rows I think. This should resize all the cells so that all the info is viewable
Old Feb 4, 2004 | 01:52 PM
bl^5's Avatar
Got da Internet Goin Nutz
After pasting go to the top of your cols and double click on the line between the top of each col (ie the black line between the A and B, B and C, C and D, etc....).
Old Feb 4, 2004 | 02:06 PM
Jonesi's Avatar
Let him respond first a) he may have fixed it b) still not 100% sure what he is asking
Old Feb 4, 2004 | 02:17 PM
phipark's Avatar
Not Asian
Ok, this is what he is saying. The cols/rows of the first sheet are smaller than that of the second sheet. So, when he pastes the second sheet on the first sheet, the first sheet will show huge spaces or widths, while the second looks normal.
The best solution that I have is to wrap text the cells and fool around with the size.
Old Feb 5, 2004 | 01:12 PM
Time to POWER UP!!
What phipark said is whats happening. I figured out a way to print it but it looks like shit.
I have 2 spread sheets with different sized cells. When i put them on the same sheet the sizes get all screwed up.
Old Feb 5, 2004 | 01:18 PM
Jonesi's Avatar
I understand.. Sometimes you have to weigh the options between using Word and Excel.. Excel you can't individually size each block/cell.. It must be the whole rows/row.. But sometimes you can merge cells together to make it fit a little better.. If it's nothing personal or confidential you can send me the file and I can try and dress it up for you..
Old Feb 5, 2004 | 01:28 PM
Time to POWER UP!!
i'll send it to you tomorrow. Im off today
Old Feb 5, 2004 | 01:42 PM
Jonesi's Avatar
swjones88@hotmail.com
Old Feb 6, 2004 | 11:23 AM
Time to POWER UP!!
you have mail.
Old Feb 6, 2004 | 11:26 AM
Jonesi's Avatar
k, i'll work on it for ya..
Old Feb 6, 2004 | 11:58 AM
Jonesi's Avatar
ok, got it.. Now you got to tell me how you want it arranged.. All on 1 page ? Obviously you want the top the same but how do you want the bottom 2 arranged..
Old Feb 6, 2004 | 05:54 PM
Time to POWER UP!!
You have mail (again)
Old Feb 7, 2004 | 12:10 PM
Jonesi's Avatar
Damnt took 3 hours but it's finally done..! Sent the files back.. Had to use excel formats and convert over to word.. Never knew you could do that before.. Worked beautiful..
Dec 7, 2020 05:39 PM
Aug 15, 2019 12:58 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
