Free WiFi IP Map/List
Old Mar 25, 2015 | 11:53 AM
stogie1020's Avatar
Needs more Lemon Pledge
Does anyone know of any location specific maps or lists of free wifi access point IP addresses?
IE, in a town, a listing of all business that offer free wifi and the associated access point IP addresses?
Old Mar 25, 2015 | 01:10 PM
Most IP Addresses are private and NAT'd so you can go to 90 out of 100 public hot spots and they'll usually use the same if not similar IP address range of 192.168.x.x.
Are you asking if there's a map of free wifi access points? I'm curious as to the need for IP addresses as they may not provide value to you.
Old Mar 25, 2015 | 01:23 PM
stogie1020's Avatar
External IPs...
When I send an email from starbucks, it has the external IP address in the header. If I know a person was in north east Phoenix, AZ and I see the IP address they posted to the web from or logged into their gmail from to send a message, I would like to be able to check the IP against a database of known public access IPs to see if they were likely using a "free access point" or other.
I am wondering if there is any currently available listing or map of IP address used at public access wifi spots? I know they can change, but most business have static IPs.
Old Mar 25, 2015 | 02:03 PM
Whiskers's Avatar
Go Giants
IP Location Finder - Geolocation
Old Mar 25, 2015 | 02:11 PM
stogie1020's Avatar
Originally Posted by Whiskers
Thanks, I was hoping to narrow it down a LOT further...
Also, hoping to be able o check a known IP against a listing to see if it's "known public access" or not.
Old Mar 25, 2015 | 02:14 PM
Whiskers's Avatar
Go Giants
I think that may require law enforcement.
Old Mar 25, 2015 | 02:19 PM
External IPs...
AHH! Apologies for misinterpreting. That clarified things immensely.
So essentially you're trying to look for an equivalent to a whois entry for a specific IP address to see if its tied to a specific free wifi access point (i.e. starbucks) ?
Not sure if that's viable but I'm curious if someone can chime in that knows better.
Old Mar 25, 2015 | 03:00 PM
stogie1020's Avatar
Yup, exactly. I don't know if anyone has wardriven my area and associated free/open WAPs with external IPs, but I would love to see the results if they have.
Old Mar 26, 2015 | 01:18 AM
#1 STUNNA's Avatar
Sanest Florida Man
Most of those places probably have dynamic IPs so that list would need to be constantly updated
Old Mar 26, 2015 | 11:31 AM
stogie1020's Avatar
Why would most business have dynamic IPs for their WAP? Last time I checked, most businesses DONT have dynamic IPs. Even my residential connection that is "dynamic" rarely changes unless I swap out the modem.
Old Mar 31, 2015 | 01:48 PM
Ero's Avatar
Ero
I believe the IP in email headers is the IP of the SMTP server, not the person's ISP's IP.
That being said, if you have something like a web form on your site that captures IPs, i'd use the resource above to narrow down the ISP, which would at least hint in the right direction. (e.g. starbucks uses AT&T almost everywhere I believe)
Old Apr 5, 2015 | 12:27 PM
doopstr's Avatar
Static IP used to be the standard when your only option was T1 or greater type of connection from a telco. Comcast/FIOS business will give you a dynamic unless you pay extra for static. Most small businesses probably don't need the static. The days of small businesses wanting to run a web server or email server onsite are quickly going away.
Old Apr 5, 2015 | 12:53 PM
Ken1997TL's Avatar
Various wardriving databases likely have something like that, at least they used to.
Old Apr 6, 2015 | 12:02 PM
stogie1020's Avatar
yeah, was doing some research on this...
Old Apr 7, 2015 | 04:21 PM
#1 STUNNA's Avatar
Sanest Florida Man
many of my small business clients don't have static IPs.
Old Apr 8, 2015 | 01:16 PM
stogie1020's Avatar
While technically true, how often do your dynamic IPs really change?
Back when we all dialied in to AOL it may have changed a lot, but now, not so often...
Old Apr 10, 2015 | 01:15 PM
doopstr's Avatar
I think mine will change if I reboot my router, other than that I've never noticed that it changes. Part of the DHCP renewal process is that the client is supposed to ask the DHCP server for renewal lease of its current IP. 99% of the time the DHCP server will say ok.
Jamus22
Jun 11, 2023 10:08 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
SiClone
Oct 1, 2015 10:22 PM
steve
Sep 30, 2015 09:23 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
