Excel question
Excel question
Ok I am trying to make a little macro that will hide cells that contain "0" or "" (nothing). The following code below works when I just do it for one cell:
If Cells(13, 3) = "" Or Cells(13, 3) = "0" Then
Rows("12:13").Hidden = True
End If
But the following code below does not work when there is an actual # in cell C24 and C25 & C26 are empty, it will still hide the cells. This happens when C25 has a # in it and C24 & C26 are empty. BUT when C24 & C25 are empty, and C26 has a # in it, the cells won't be made hidden...
If Cells(24, 3) = "" Or Cells(24, 3) = "0" & _
Cells(25, 3) = "" Or Cells(25, 3) = "0" & _
Cells(26, 3) = "" Or Cells(26, 3) = "0" Then
Rows("23:26").Hidden = True
Else
Rows("23:26").Hidden = False
End If
And I added the "Else" this morning and prior to that the same results occurred. If anyone can help I would greatly appreciate it! Thanks!
End If
Else
End If
I'm not an Excel expert, but I think your ANDs and ORs might be getting "mixed up" due to operator precedence rules. Will it let you put parentheses around the OR conditions, like this?
If (Cells(24, 3) = "" Or Cells(24, 3) = "0") & _
(Cells(25, 3) = "" Or Cells(25, 3) = "0") & _
(Cells(26, 3) = "" Or Cells(26, 3) = "0") Then
Else
End If
Else
End If
O no.. but now when all 3 are empty it won't hide the cells...
Else
End If
Else
End If
Hmmm... dunno why it won't let you put them around the 1st line... Have you tried this?
If ((Cells(24, 3) = "" Or Cells(24, 3) = "0") & _
(Cells(26, 3) = "" Or Cells(26, 3) = "0")) Then
Else
End If
Else
End If
I am going to try the update, but this is for work, so even if it works here it really has to work at work. So if anyone has a solution besides the update (if that even works) then I'd appreciate it!
Maybe you need to be using "AND" instead of "&"? From my Excel Help, it looks like "&" is a string concatenation operator, and "AND" is a comparison operator. Worth a shot, right?
If ((Cells(24, 3) = "" Or Cells(24, 3) = "0") AND _
(Cells(25, 3) = "" Or Cells(25, 3) = "0") AND _
Else
End If
Else
End If
This worked for me.
Sub Macro1()
If Cells(24, 3) = vbEmpty Or Cells(24, 3) = "0" & _
Cells(25, 3) = vbEmpty Or Cells(25, 3) = "0" & _
Cells(26, 3) = vbEmpty Or Cells(26, 3) = "0" Then
Else
End If
End Sub
Sub Macro1()
Else
End If
End Sub
Originally Posted by hornyleprechaun
Yup worked like a charm.. thanks again! This concludes the hornyleprechaun and elessar excel help thread
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
rboller
09-23-2015 02:49 PM
