Excel question
Old Jun 30, 2007 | 10:33 AM
hornyleprechaun's Avatar
Bent = #1
Excel question
Ok I am trying to make a little macro that will hide cells that contain "0" or "" (nothing). The following code below works when I just do it for one cell:
If Cells(13, 3) = "" Or Cells(13, 3) = "0" Then
Rows("12:13").Hidden = True
End If
But the following code below does not work when there is an actual # in cell C24 and C25 & C26 are empty, it will still hide the cells. This happens when C25 has a # in it and C24 & C26 are empty. BUT when C24 & C25 are empty, and C26 has a # in it, the cells won't be made hidden...
If Cells(24, 3) = "" Or Cells(24, 3) = "0" & _
Cells(25, 3) = "" Or Cells(25, 3) = "0" & _
Cells(26, 3) = "" Or Cells(26, 3) = "0" Then
Rows("23:26").Hidden = True
Else
Rows("23:26").Hidden = False
End If
And I added the "Else" this morning and prior to that the same results occurred. If anyone can help I would greatly appreciate it! Thanks!
Old Jun 30, 2007 | 10:37 AM
elessar's Avatar
Return of the Ring
I'm not an Excel expert, but I think your ANDs and ORs might be getting "mixed up" due to operator precedence rules. Will it let you put parentheses around the OR conditions, like this?
If (Cells(24, 3) = "" Or Cells(24, 3) = "0") & _
(Cells(25, 3) = "" Or Cells(25, 3) = "0") & _
(Cells(26, 3) = "" Or Cells(26, 3) = "0") Then
Else
End If
Old Jun 30, 2007 | 10:44 AM
Bent = #1
I get a "Type mismatch" error when I try to do that..
Old Jun 30, 2007 | 10:47 AM
Bent = #1
BUT I didn't put parentheses around the first line, and just the bottom 2 lines and it worked! Thanks and repped!
Old Jun 30, 2007 | 10:49 AM
Bent = #1
O no.. but now when all 3 are empty it won't hide the cells...
Else
End If
Old Jun 30, 2007 | 10:54 AM
elessar's Avatar
Return of the Ring
Hmmm... dunno why it won't let you put them around the 1st line... Have you tried this?
If ((Cells(24, 3) = "" Or Cells(24, 3) = "0") & _
(Cells(26, 3) = "" Or Cells(26, 3) = "0")) Then
Else
End If
Old Jun 30, 2007 | 10:56 AM
Bent = #1
Same type mismatch error
Old Jun 30, 2007 | 10:59 AM
Bent = #1
This could be my problem..
http://support.microsoft.com/kb/821292
Old Jun 30, 2007 | 11:09 AM
Bent = #1
I am going to try the update, but this is for work, so even if it works here it really has to work at work. So if anyone has a solution besides the update (if that even works) then I'd appreciate it!
Old Jun 30, 2007 | 11:19 AM
Bent = #1
Update didn't work
Old Jun 30, 2007 | 11:21 AM
elessar's Avatar
Return of the Ring
Maybe you need to be using "AND" instead of "&"? From my Excel Help, it looks like "&" is a string concatenation operator, and "AND" is a comparison operator. Worth a shot, right?
If ((Cells(24, 3) = "" Or Cells(24, 3) = "0") AND _
(Cells(25, 3) = "" Or Cells(25, 3) = "0") AND _
Else
End If
Old Jun 30, 2007 | 11:41 AM
Bent = #1
Yup worked like a charm.. thanks again! This concludes the hornyleprechaun and elessar excel help thread
Old Jun 30, 2007 | 11:45 AM
kona's Avatar
This worked for me.
Sub Macro1()
If Cells(24, 3) = vbEmpty Or Cells(24, 3) = "0" & _
Cells(25, 3) = vbEmpty Or Cells(25, 3) = "0" & _
Cells(26, 3) = vbEmpty Or Cells(26, 3) = "0" Then
Else
End If
End Sub
Old Jun 30, 2007 | 12:12 PM
sonnyg80's Avatar
stop doing work on your birthday!!
Old Jun 30, 2007 | 01:27 PM
elessar's Avatar
Return of the Ring
Awesome! Now like sonny said, get the hell out there & start celebrating your birthday, dude!!
Old Jun 30, 2007 | 01:34 PM
Bent = #1
I can't yet! My g/f is getting her hair highlighted, so whenever she is done I can leave and start boozing
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
rboller
Sep 23, 2015 02:49 PM
