DVD Burning Speed Question
Old Jun 18, 2006 | 11:07 PM
Sly Raskal's Avatar
Question DVD Burning Speed Question
So I've got dual sony dvd burners on my computer. I'm using Roxio Easy Media Creator Suite 8.
Right now I'm trying to burn copys of my wedding dvd and I'm burning from an ISO image.
When burning to both drives, the speed fluctuates between under 1x and at most 3x. but the burners can support 16x. And the actual DVDs can support 16x speed as well.
Why can't I get it to burn any higher than 3x?
It's taking forever to burn these damn DVDs
I've tried messing with the amount of hard disk space the buffer underun can use. But I haven't actually tried disabling the buffer underrun for fear of poor dvd copying.
Any ideas?
Old Jun 18, 2006 | 11:14 PM
FISHYTL's Avatar
whats the speed rating on the blank media?
Old Jun 18, 2006 | 11:15 PM
Sly Raskal's Avatar
^^^ 16x
Old Jun 18, 2006 | 11:23 PM
F900's Avatar
If you use NERO, it will tell you the Max spin rate you can burn at, then aleast you will know whats causing to you burn so slow.
Old Jun 18, 2006 | 11:29 PM
FISHYTL's Avatar
i use nero and have no problems
Old Jun 18, 2006 | 11:31 PM
Sly Raskal's Avatar
The last time I checked, EMC (Easy Media Creator) has a tool that can identify the media and tell you what the spin rate is as well. And last time it did report 16x.
But I'll check it again as soon as the current discs are finished burning.
Old Jun 18, 2006 | 11:35 PM
Sly Raskal's Avatar
Just checked, it doesn't report the max spin rate of the disc. Only the burning device.
But I still don't see how that is affecting the very slow burn rate.
Old Jun 18, 2006 | 11:37 PM
Sly Raskal's Avatar
Could it be because the read time from accessing the hard drive is slowing it down since I'm burning from an ISO image on the hard drive?
Old Jun 18, 2006 | 11:41 PM
F900's Avatar
Check to see if there is any firmware updates for your DVD burner
Old Jun 19, 2006 | 12:49 AM
Sly Raskal's Avatar
It looks as though I do already have the up to date firmware for both drives.
drone619
Jan 26, 2016 07:09 PM
IIDXholic
Oct 8, 2015 07:53 AM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
phillyguerrilla
Sep 11, 2015 06:39 PM
