DVD Burning Speed Question
So I've got dual sony dvd burners on my computer. I'm using Roxio Easy Media Creator Suite 8.
Right now I'm trying to burn copys of my wedding dvd and I'm burning from an ISO image.
When burning to both drives, the speed fluctuates between under 1x and at most 3x. but the burners can support 16x. And the actual DVDs can support 16x speed as well.
Why can't I get it to burn any higher than 3x?
It's taking forever to burn these damn DVDs
I've tried messing with the amount of hard disk space the buffer underun can use. But I haven't actually tried disabling the buffer underrun for fear of poor dvd copying.
Any ideas?
Any ideas?
Originally Posted by F900
If you use NERO, it will tell you the Max spin rate you can burn at, then aleast you will know whats causing to you burn so slow.
But I'll check it again as soon as the current discs are finished burning.
Just checked, it doesn't report the max spin rate of the disc. Only the burning device.
But I still don't see how that is affecting the very slow burn rate.
Check to see if there is any firmware updates for your DVD burner
IIDXholic
Oct 8, 2015 07:53 AM
Skirmich
Sep 15, 2015 06:41 PM
i use nero and have no problems
