cant delete .exe in windows advice plz
Old Feb 5, 2003 | 10:58 PM
MaCe's Avatar
fellow MASShole
i guess i installed an actaul pop up add generator or some shit .. about online casinos and what not i leave my cpu for 10 min and i have like 30 adds on screen ...
now under my program files i have a shit load of these add ware/pop up folders but i cant delete em cause they all say "access denied file in use ".. ive rebooted .. still dont work and ideas on how to get rid of em and there not viruses so my anti virus doesnt care about em ... its really pissin me off oh and im runnin XP so there no dos ... thats how i usually got rid of annoyin files back in the day ...
MaCe
Old Feb 5, 2003 | 11:12 PM
Samer007's Avatar
Smack My B*tch Up
Download this free program called "Ad-Aware"
http://download.com.com/3000-2144-10045910.html
Old Feb 5, 2003 | 11:21 PM
amir was here's Avatar
start>program files> Command Prompt
i once downloaded this video of kazaa, it was SUPPOSED to be a MILF putting on pantyhose, but instead it was a 40 year old female midget, a real midget, having sex....it was nasty, and it would not delete...i had to use command prompt.
Old Feb 6, 2003 | 12:35 AM
AkuraCLS's Avatar
ALi G in the House!
YEHHHHHHHHH! amir!
Old Feb 6, 2003 | 01:47 AM
HellaWhat's Avatar
*Hella* isn't a word.
Hit CTRL+ALT+DEL. In Win9x and Me(I think) a task list should pop up and halt processes on your computer. Look for the stupid program, kill it and then delete the EXE. Do the same for NT4/2K and another window will popup, click Task List. Select the process tab and end the task (the name of the .exe) and you should be able to delete it. In WinXP, depending on ur config, u can either use the above method listed for 2k/NT. If that doesn't work, right click an empty area of the task bar, u should get a popup menu select "task mnaer". Again, select the process tab and end the process, then delete it.
Knowing a lot of these programs startup when u login, there's another way u can stop it. Most of the time, it uses the registry to automatically run the program. If it's machine specific, the program would put a pointer here to tell Windows o automatilaly launch it.
1. Run Regedit
2. Look Under : HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run
3. Locate the registry entry that points to the name of the exe that is launching. Delete the entry and delete the file.
Hope this helps.
Old Feb 6, 2003 | 01:54 AM
CLSter's Avatar
Under the radar
There a real asshole site called Xupiter that downloads a bunch of crap WITHOUT your approval and AD-AWARE can't catch it. Try Spy-Bot it gets more updates for all the newest bastards out there: http://security.kolla.de/
Old Feb 6, 2003 | 01:59 AM
HellaWhat's Avatar
See my post above. Xupiter usually gets on ur comp through IE. When u lower all the permissions, it allows a website to isntall with or without ur consent. Xupiter puts a registry key in the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run Key so that everytime you login, it launches. They put it here cause it's less obvious then in the folder: \documents and settings\[username]\start menu\programs\startup and fewer ppl are less likely to find it.
Old Feb 6, 2003 | 02:19 AM
mt6forlife's Avatar
Ad Aware 5 with the September 2002 ref file DOES catch Xupiter. Done it a million times.
Old Feb 6, 2003 | 07:39 AM
Samer007's Avatar
Smack My B*tch Up
The above link for Ad aware is for ver 6, and its the most updated one.
Old Feb 6, 2003 | 10:05 AM
ChodTheWacko's Avatar
Moderator Alumnus
That being said, you can disable it pretty easily in xp by doing a run (start -> run) of msconfig, click on the 'startup' tab , and turn off whatever you want.
It's useful for getting rid of annoyware like realplayer too.
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
soupi
14
Nov 15, 2015 11:15 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
