SPC Camber Kit: CL / TL / RL / TSX / Accord V6
This is a Groupbuy for SPC Camber Kits. The pricing event will consist of the SPC Camber Kits for the the Acura CL/TL/RL/TSX and the Honda Accord V6. Here is a quick description:
These adjustable upper ball joints make front camber adjustments on later model Hondas and Acuras. By replacing the factory ball joint, this sliding ball joint allows for greater camber changes than previously available. Incorporating an OE quality replacement ball joint, this sliding plate assembly is perfect for vehicles that have been lowered for performance, or retain the factory ride.
Installation time: .8 hours
EZ Arms XR make rear camber adjustment possible on cars that have been lowered for performance and for those that retain the stock ride height. Simply replace the OE arm with the EZ Arm XR, and you can adjust the rear camber.
Adjustment range: -2.00 degrees to +4.00 degrees.
NOTE: An OE style ball joint is integrated in this arm.
Shipping times will depend upon your location. Prices based on shipping to 48 continental states in the U.S.
The following payment terms are accepted: Bank or Teller Check, Money Order, sent to:
Excelerate LLC
998 West Main St
Branford, CT 06405
You may also send payment to Excelerate@sbcglobal.net via Paypal. However, if you pay through Paypal you must add 3% to the transaction.
Applications are taken straight from www.spcperformance.com. The prices will run as follows:
SPC Front Camber Kit Part # 67125 - $150 shipped
Adjustment range: -1.50° to +1.50°
Applications for Part # 67125
- Acura: 96-03 CL, 96 - 05 TL, 04-05 TSX
- Honda: 98 - 05 Accord
SPC Front Camber Kit Part #67320 - $160 shipped
Adjustment range: +1.50° to +3.0°
Applications for Part # 67320
& nbsp; - Honda: 98 - 05 Accord
SPC Rear Camber Kit Part # 67090- $150 shipped
Applications for Part # 67090
- Acura: 01-03 3.2CL, 99 - 03 3.2 TL, 96-04 RL
- Honda: 98-02 Accord
SPC Rear Camber Kit Part # 67095- $150 shipped
Applications for Part # 67095
- Acura: 04-05 TL
SPC Rear Camber Kit Part #67290 $160 shipped
Applications for Part # 67290
- Acura: 04-05 TSX
*****A camber kit will include BOTH sides!*****
AIM Screen Name: Excelerate04
E-mail: Excelerate@sbcglobal.net
or PM me.
RETURN POLICY
- ALL RETURNED AND/OR CANCELLED ORDERS ARE SUBJECT TO A 25% RE-STOCKING FEE PLUS ALL SHIPPING CHARGES (Includes original and return S&H fees).
- ALL AUTHORIZED RETURN MERCHANDISE MUST BE NEW, UNUSED, AND IN ITS ORIGINAL PACKAGING. ALL DOCUMENTATION, WARRANTY CARDS, INSTRUCTIONS, AND HARDWARE MUST ALSO BE RETURNED.
- ITEMS MAY BE RETURNED WITHIN 15 CALENDAR DAYS FROM THE RECEIPT OF MERCHANDISE.
- SPECIAL ORDERS ARE NOT RETURNABLE.
EXCELERATE LLC
998 West Main St
Branford, CT 06405
(P) 203-483-6100 (F) 203-483-6101
www.ExceleratePerformance.com
Joshua Lockwood
Owner
Excelerate LLC
998 West Main St
Branford, CT 06405
- Acura: 04-05 TL
- Acura: 04-05 TSX
or PM me.
RETURN POLICY
EXCELERATE LLC
998 West Main St
Branford, CT 06405
Joshua Lockwood
Owner
Originally Posted by rondog
Man, I have a TEIN SS Coilover suspension, with a no finger gap, which camber kits should I get?
If you have more than a 1.5" drop in the front SPC recommends their 67320 kit as opposed to the 67125 kit which is for drops less than 1.5".
8AT > 6MT
i called SPC regarding camber kit part number 67320 and they said that it only comes as one and if you want one for both sides, you would have to buy two boxes of 67320. your post says that a camber kit will include both sides. so which one is it? because that means if its sold as a single, that means it would cost more than 300 dollars for a front camber setup
Originally Posted by Malayalee King
Still going on?
link?
Just received the front ball joints and installed em today, with a little problem that I had to overcome. The cotter pins were too big to fit into the holes they are supposed to go into. I actually had to drill those holes to make them slightly larger so the pins would fit. Kind of annoying that they aren't the correct size in the first place. Be prepared to drill if you order these.
IBankMouse
06-13-2020 12:53 PM
Eggs999bacon
09-24-2015 10:08 AM
