Need some help locating the wiring diagrams for a 2007-2008 side mirrors and the 2004-2006 side mirrors. Going to swap mine out, I have a 2005 and picked some up from a 2007-2008 with blinker.
I did a quick search and didn't come up with anything.
Driver side is easiest to wire.
- Pink Wire with Black line is the blinkers
-Tap the wire and run it through the door through the grommet of the door
-Open up your door sill and open the loom. Look for a redwire with a blue line , tap that ur done.
Passenger
-Pink wire with black line is the blinker
-Run the wire back to the turn signal in rear, it's the white wire.
*I could not find the correct white wire in the door sill of passenger side after 5 different white wires--so i gave up and ran the wire back to rear turn signal. You COULD wire to front turn signal but there is literally no room to solder without taking off wheel, fender liner/bumper
GLUCK!
Passenger
