Mirror wiring diagram
Old 08-19-2017, 06:11 PM
4DGSR's Avatar
Hi guys,
Need some help locating the wiring diagrams for a 2007-2008 side mirrors and the 2004-2006 side mirrors. Going to swap mine out, I have a 2005 and picked some up from a 2007-2008 with blinker.
I did a quick search and didn't come up with anything.
Thanks for the help!
Old 08-19-2017, 06:18 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
There is a DIY thread about this however I suspect most of the pics goes MIA since photobucket decide to be a bucket of turd.
Edit: Found the thread with update pics of wiring diagram.
https://acurazine.com/forums/3g-tl-a...-637014/page3/
Here another one with some pics.
https://acurazine.com/forums/third-g...-06-tl-779015/
Old 08-20-2017, 02:18 AM
4DGSR's Avatar
Thanks. Just noticed the driver mirror I picked up has a cut harness. Still need to see the wire colors...
Old 08-21-2017, 01:57 PM
DesertMistTL's Avatar
I did this recently.
Driver side is easiest to wire.
- Pink Wire with Black line is the blinkers
-Tap the wire and run it through the door through the grommet of the door
-Open up your door sill and open the loom. Look for a redwire with a blue line , tap that ur done.
Passenger
-Pink wire with black line is the blinker
-Run the wire back to the turn signal in rear, it's the white wire.
*I could not find the correct white wire in the door sill of passenger side after 5 different white wires--so i gave up and ran the wire back to rear turn signal. You COULD wire to front turn signal but there is literally no room to solder without taking off wheel, fender liner/bumper
GLUCK!
Old 08-22-2017, 08:56 PM
4DGSR's Avatar
Thanks. Going to pop off the panels tomorrow and try hooking them up.
Old 04-24-2019, 12:21 PM
Real Raf's Avatar
Passenger
GLUCK!
What do I do with the red and blue wire ?
Old 05-04-2019, 02:29 AM
solder
Amon Gift
08-23-2022 08:40 AM
mrphilipanderson
11-18-2016 06:58 PM
EE4Life
2G NSX (2017+)
07-14-2016 09:09 PM
rets
01-01-2013 09:50 PM
JSuppi
10-14-2001 09:29 AM
Quick Reply: Mirror wiring diagram
