E-115: DIY (Improved) - Installing '07/'08 Mirrors on '06 TL
Old Jun 6, 2010 | 09:44 PM
Khalil.e's Avatar
EDIT: Can a mod please help with resizing the photos? Thanks! (If you could please change the title do DIY, that would be great : )
Decided to attack my mirror install this weekend - first cosmetic mod on the TL.
After reading the DIY, I was quite worried about having to fish a new wire from the mirror, through the door and especially through the plastic loom between the door and the cabin.
I did, however, find a (in my opinion) better way to wire the mirror up.
Similar to other '06 TL owners, my drivers side mirror was plug and play.
When trying to figure out how I was going to pull a wire through the loom between the door and the cabin, I was intrigued as to how there was a wire in the harness for power to the mirror LED's, yet no power.
I traced the wire through the door, and through the wire loom between the door and cabin.
Traced it from the entry point to where it split into three different connectors. The wire white with silver spots on it, and plugs into the far end of the first connector.
The top of that same connector has no wire going into it.
There she is:
Wire tap from tail light:
Wire tapped up front:
Left:
Right:
On:
Off:
Old Jun 6, 2010 | 09:45 PM
Khalil.e's Avatar
Sorry for the huge pics guys.
Old Jun 6, 2010 | 09:57 PM
Khalil.e's Avatar
Video
http://img153.imageshack.us/img153/2...1006061528.mp4
Old Jun 6, 2010 | 10:05 PM
csmeance's Avatar
Title changed and Pics Resized! Into the 3G garage this goes!
Old Jun 6, 2010 | 10:11 PM
CLtotheTL32's Avatar
Damn those look great.
Added to my never ending "to-do list".
Old Jun 7, 2010 | 12:52 AM
Khalil.e's Avatar
Oh...and may as well change your cabin filter while your in there!
Thanks for the comments...they look pimpin cause of the smoked look ...matches the front (and soon rear) side markers .
Old Dec 31, 2010 | 02:43 PM
sgtapmystical's Avatar
SAME HERE! Now on to find replacement mirrors...
Old Dec 31, 2010 | 04:56 PM
818steez06's Avatar
Shit looks hott, how long did it take you to do overall?
Old Dec 31, 2010 | 05:01 PM
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
will it work on a 05?
Old Jan 1, 2011 | 01:48 PM
o4Komodo's Avatar
Rev High; Drive Happy
Yes. Small small chance the wire might be a different color but I doubt it.
Old Jan 5, 2011 | 12:41 PM
ReignMan's Avatar
6th Gear
Where do you buy replacement mirrors?
Old Jan 5, 2011 | 12:44 PM
dealer, ebay, the black market.
Old Jan 5, 2011 | 12:47 PM
ReignMan's Avatar
6th Gear
Thanks! If anybody has any links please post!
Old Jan 5, 2011 | 12:54 PM
www.ebay.com
www.yourlocalacuradealer.com
Old Jan 6, 2011 | 11:49 AM
vuuha05's Avatar
Man...would this be impossible on my '05??it looks so cool>_<
Old Jan 13, 2011 | 10:55 PM
Sandals's Avatar
Did anyone who did this notice that the nuts on the old mirror were 8mm and on the new mirror they were all 10mm. You might want to add that to the DIY because I had to make the hole picture on the door for the bolts to fit through them.
Also, Don't know if this has been mentioned but are the 05's pre-wired as well.
Old May 1, 2011 | 09:42 AM
Mce22Usa45's Avatar
http://www.acuraoemparts.com/delray/...%29&pp=0&np=25
Old Apr 1, 2012 | 02:33 AM
A SiQ TL's Avatar
$258 a piece. This goes waayyyy down on my to do list.
I'm sure I could probably get them cheaper at a wrecking yard but still going to be low on the list. also some 04-05 owners wont be able to do this because of the color changes. SSM to ASM, and ABP to RBP IIRC.
Old Jun 1, 2012 | 06:04 PM
slimmatic's Avatar
6th Gear
im definitely gonna up grade to those
Old Feb 22, 2013 | 02:56 PM
Project_CLean's Avatar
MMkay.
same procedure for 04? anyone with a diy for the TLs without the pre-wired harness?
Old Apr 18, 2013 | 03:49 PM
dav3455's Avatar
3rd Gear
^same with you, anyone done this befor on a 04?
Old Jan 12, 2014 | 05:08 AM
LowLife_KiiD's Avatar
Do you have the old DIY of this from scratch? Been searching but it always come back to this
Old Jun 10, 2015 | 12:01 AM
Jpro's Avatar
BANNED
Any update?
I have an 04 I picked up a set of 07 side mirrors. I'm trying to find the signal wire from the mirror any help would be greatly appreciated
Old Jun 10, 2015 | 07:18 AM
It's connected to the mirror
There's only so much an Internet forum can help you kind sir.. You'll have to take apart the door and just trace the wire from the actual side mirror itself, we can't do it remotely yet..
(Acura is working on that online remote diagnostic.. just as soon as they're done with the NSX)
Old Jun 10, 2015 | 11:06 AM
06TLMatt's Avatar
I like.
Old Jun 13, 2015 | 10:27 AM
DMZ's Avatar
DMZ
Head a da Family
FYI folks,the first 3,000 2004 TL's produced had turn signal mirrors on the window sticker! Someone at Acura or one of their suppliers fucked up!
Old Jun 13, 2015 | 10:33 AM
guitarplayer16's Avatar
That's definitely interesting.
2004 CDM TLs had turn signal mirrors that we see on 07/08 TLs.
Also note the clear diffusers are the same as on the Type-S TLs.
Blacked out headlights also, without the inner DRL shroud on 07/08 TLs.
Old Jun 27, 2015 | 07:45 PM
Jpro's Avatar
BANNED
I was really just taking the lazy way out . I swapped the mirrors took me no more then 30 min wired up looking good thanks
Old Mar 10, 2016 | 11:38 PM
natenolan2428's Avatar
7th Gear
Awesome DIY, cant wait to try this, just need to find some 07/08 mirrors for my 05:/ anybody have any suggestions on where I could find a pair?
Old Mar 13, 2016 | 03:07 PM
mrseattle's Avatar
4th Gear
You can find the mirrors at Quality Auto Glass they are not cheap and customer service is not good with my experience. Check reviews before purchase wish I did.
Old Mar 13, 2016 | 03:11 PM
mrseattle's Avatar
4th Gear
Somehow the link got messed up should be glassrack.net
Old Apr 14, 2016 | 02:35 AM
DesertMistTL's Avatar
reviving this. after tapping the lone wire to tail light, does the wire then go back into the top connector? Does it need a pin to go into the connector or just tap to the white wire on the next connector?
Old Apr 17, 2016 | 01:50 PM
DMZ's Avatar
DMZ
Head a da Family
FYI folks,the first 3,000 2004 TL's produced had turn signal mirrors on the window sticker! Someone at Acura or one of their suppliers fucked up!.
What really pisses me off is the fact that the models above and below the TL for 2004, BOTH the RL and the TSX came with turn signals mirrors! WTF Acura?
Old May 29, 2016 | 04:47 AM
for anyone wondering what color the rear turn signal positive wires are
red/blue for driverside and white for passenger.
Old Apr 17, 2017 | 12:58 PM
DeathLens's Avatar
Bumping this.
Currently doing this. Exactly which wire do I tap into? White with gray spots or just white? Can someone point exactly where do I tap into for the passenger side? This is by the kick panel.
Old Apr 17, 2017 | 06:40 PM
Originally Posted by DeathLens
Bumping this.
I just wired to the white wire by the rear tail light. I spliced 4 wires trying to find the right white wire in the door sill loom with no luck. Just save the headache and run the wire back there.
Old Apr 18, 2017 | 09:31 PM
Chad05TL's Avatar
The original post looks like the lights are on with the parking lights instead of the blinker. And the plastic looks really dark. It doesn't look oem. It looks good, but not oem..
Old Apr 19, 2017 | 03:57 PM
DeathLens's Avatar
Thanks man. I ended up doing it this way and what a pain in the ass! I had to take the rear seats out just to put the rear panels back in properly. And unfortunately, my 05 is not prewired for the driver side so I also had to do that side too and running the wires through the door jam was a pain.
Old Apr 19, 2017 | 03:59 PM
DeathLens's Avatar
They're just tinted.
Old Apr 19, 2017 | 04:13 PM
314_04TL's Avatar
I have been meaning to do this. I have been sitting on a pair for like 6 months
