No A/C in RL. Bypass relay & recharge?
Old 06-12-2013, 02:13 PM
Stoianoff31's Avatar
Hello All,
The A/C in my 2005 RL went warm over the course of 3-4 days. The compressor was engaging at start-up a few different time and would continue working until I shut off the car. Now A/C compressor will not turn on, I am assuming this is because of low pressure and no freon. Has anyone had any experience bypassing the relay which would engage the compressor straight from the battery? I had to do this with an older sports car, but I am hesitant to do it in my RL. Once the compressor has engaged I will recharge it. No running compressor means no recharge.
Thank you
Pete
Old 06-12-2013, 02:49 PM
oo7spy's Avatar
Received 7,247 Likes on 4,858 Posts
The 2005 A/C I issues have been well documented here. I think the stator is the majority culprit. Many have trouble shooted their issues by directly applying power and documented that as well. The service manual is probably going to a be a good friend in this process.
Old 06-12-2013, 03:22 PM
I checked the RL garage and didn't find much of anything
Old 06-12-2013, 03:33 PM
oo7spy's Avatar
I was thinking more along the lines of a search, but I'll do it for you.
https://acurazine.com/forums/showthread.php?t=789051
https://acurazine.com/forums/2g-rl-2005-2012-76/potential-solution-ac-problems-05s-06s-500188/
https://acurazine.com/forums/2g-rl-2005-2012-76/c-compressor-help-866941/
https://acurazine.com/forums/2g-rl-2005-2012-76/005-2005-2008-rl-c-hot-air-%2Afix%2A-diy-w-pics-864675/
This is all within the past year. There are many more.
Old 06-12-2013, 03:38 PM
thank you! much appreciated!
Old 06-12-2013, 04:13 PM
checked fuses and relays. no luck. anyone done a relay bypass with paperclip trick?
Old 06-13-2013, 07:23 AM
andrewmr's Avatar
If you determine the problem is the clutch and stator (common issues), I have one I bought that I thought would fix my problem but I ended up replacing the whole unit.
Let me know, I'll save you a few bucks.
Old 06-14-2013, 01:02 PM
power going to compressor, not running. clutch wont grab. I pushed in the clutch and still no grab, it was spinning. Help?
Old 06-14-2013, 04:27 PM
sOLLEx's Avatar
Ohm out the field coil in the service manual procedure. Then replace the field coil (stator) and the clutch and call it a day
Old 06-14-2013, 08:48 PM
NJ06RL's Avatar
Just got the same fix done on our RL at the dealer - under Acura Care - stator and clutch replaced due to no cold air. 89k miles. All good now.
Old 06-14-2013, 09:17 PM
what does "ohm" mean? to be more clear i pushed the clutch against the compressor and could feel spinning/rubbing. obviously no magnetic catch to engage. does the field coil and clutch sound like the appropriate fix? my repair guy said to replace compressor since there is power going to it.
Im leaving for south sunday morning... great timing. ugh
Old 06-15-2013, 07:47 PM
sOLLEx's Avatar
"Ohm out" is a quick way of saying to check for the amount of resistance found in the field coil. Unless you feel like going through the service manual yourself, then i would suggest going to the dealer because it sounds like your "repair guy" is not going to save you any money by just throwing a whole compressor at the problem. That is an over-repair in most cases.
tsx_boy
12-13-2019 08:33 PM
Biggie_B
02-26-2017 11:14 AM
hashbrown
09-29-2015 12:13 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
greeneyes.hypnotize
09-27-2015 02:47 PM
Quick Reply: No A/C in RL. Bypass relay & recharge?
