Need some help bad
Old 11-28-2018, 04:00 PM
jamalwite's Avatar
Need some help bad
I recently purchased an 05 RL the previous owner stated that the car has been sitting for well over a year and his wife had been driving it for a year before that so he didn’t know how well she maintained it. I’ve done the major tune up,breaks and tires, thermostat, radiator, control arms, tire rods, motor mounts, and after all that I was driving yesterday and the all of a sudden the car felt as if it was in neutral. When I turn the car off and on it will drive for a while and do the same and it does it in drive and reverse. I have to turn the car off and on again just to move a very short distance. I was reading a different thread for a TL and it was saying to change the transmission oil and filter does anyone think this will work for me and does the RL have an external transmission filter?
Old 11-29-2018, 05:12 AM
jbird2212's Avatar
Changing to new Honda/Acura trans fluid would be a good start and as far as the external filter the RL is an internal filter
https://acurazine.com/forums/second-...ow-rpm-753017/
Old 11-29-2018, 09:53 AM
jamalwite's Avatar
Thank you.do you know if it’s hard to access the filter?
Old 11-29-2018, 10:32 AM
jbird2212's Avatar
I believe you have to drop the transmission pan to access it but not 100% sure
Old 11-29-2018, 10:38 AM
jamalwite's Avatar
Ok thank you
Old 11-29-2018, 12:32 PM
Received 8,585 Likes on 6,631 Posts
https://www.oemacuraparts.com/v-2005...c--at-atf-pipe
Filter is #3 on the list here but I'm not sure if it can be accessed externally.. THere is a cover so try and see if you can find it.
I'd replace fluid first to see if that fixes it..
Old 11-29-2018, 05:01 PM
jamalwite's Avatar
​​​​​​so I took it to a transmission shop today to get it flushed and to put the new fluid in and they said that I need a new transmission and putting new fluid and filter would be a waste of money
Old 11-29-2018, 05:11 PM
Fluid/filter/flush = ~$100
New transmission = ~$2000
I wonder why they would say that
Old 11-30-2018, 02:00 AM
pewpew's Avatar
I was going to say the same thing!
Old 11-30-2018, 05:47 AM
Fk no!TheyldstroyEvrthing
RL09's Avatar
I got worried about the tranny the moment I read that line.
Old 11-30-2018, 06:45 AM
jamalwite's Avatar
So you think it’s done too because I was
just going to have it towed some place else for the flush and new fluid I don’t want to keep driving on it if it’s not all the way gone
Old 12-01-2018, 10:15 PM
projektvertx's Avatar
Does the fluid smell burnt at all?
Old 12-01-2018, 10:59 PM
jamalwite's Avatar
I can’t smell it from the inside. But I drove it another short distance and now the check emissions light came on
Old 12-01-2018, 11:01 PM
jamalwite's Avatar
Another two things I’ve found out was my son accidentally put 87 in the tank and gave someone a jump I doubt either of these things would cause this reaction.
Old 12-01-2018, 11:30 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
No worries about the 87 AKI fuel, a tank here and there will not in any way hurt the engine; assuming the jump start was done properly, that will have no effect on the car as well.
Old 12-02-2018, 02:47 AM
jamalwite's Avatar
Thank you
Old 12-11-2018, 07:56 PM
jamalwite's Avatar
So I finally got the car towed to a different shop and had them drain and add new Acura transmission fluid I drove the car everything seemed fine for a full half hour and than it started to act up it didn’t completely stop moving like last time but I knew to stop as soon as it started slipping. At this point I guess it’s safe to assume I should get a new tranny. Any advice would be appreciated.
Old 12-11-2018, 07:59 PM
Latent car nut
horseshoez's Avatar
Search this forum for discussions related to swapping the "AV6" (Accord V6) transmission from 2006 and 2007 Honda Accords with V6 engines (not Hybrids).
Old 12-11-2018, 08:22 PM
jamalwite's Avatar
Ok
tommyg55
07-01-2013 05:20 PM
RaviNJCLs
Dating & Relationships
12-08-2004 08:41 AM
HI50
06-02-2004 08:32 PM
Quick Reply: Need some help bad
