6 speed swap in 05-09?
Old 10-16-2018, 03:15 PM
fuzzysig's Avatar
has anyone done a 6 spd transmission swap into 05-09 RL?
I want to keep the j35 but swap the 6 speed from newer rl is it all plug and play as far as TCM from newer RL?
Old 10-16-2018, 04:13 PM
Received 8,585 Likes on 6,631 Posts
@teh CL , your expertise is being requested.
The following 2 users liked this post by thoiboi:
projektvertx (10-16-2018), rlx015 (10-17-2018)
Old 10-16-2018, 06:05 PM
teh CL's Avatar
Only thing plug and play would be that the trans will bolt right up.
As for the ECU, at minimum you'll need to create a jumper harness with your ECU connectors ----> the KB2 6spd connectors/matching ECU.
That's simple enough but whether the KB1 will accept the newer ECU is the real question...
Old 10-19-2018, 12:21 PM
fuzzysig's Avatar
so its better to find a totaled kb2 and transfer everything then?
Old 10-19-2018, 07:20 PM
teh CL's Avatar
Yea that would help for sure.
​​​​​If your serious, go the jumper harness route first just in case the car accepts it.
kevinf41
10-21-2015 09:25 AM
Liquidflex81
03-24-2012 05:13 PM
poisx7
11-24-2008 09:10 PM
trewatts
02-21-2007 09:43 AM
RidinLow
08-13-2001 12:48 AM
Quick Reply: 6 speed swap in 05-09?
