for those that did the 5 speed AT to 6 speed swap
for those that did the 5 speed AT to 6 speed swap ??
what happens to the VSA ?? do u guys take it off ??
is it still functional if left on there ???
i just wanted to know the diff in a factory 6 speed i.e 03's & a swapped out Auto for manual.
You remove the VSA throttle body and you no longer have VSA. The CLS6 speed tranny have LSD (limited Slip Differential). There will be no difference in a factory 6speed and a swapped 6speed if you do it correctly
Unless installing the manual transmission into the car requires u to remove the VSA throttle body b4 it will fit or work ( which i highly doubt)
mlody
Dec 4, 2019 02:11 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
