6 speed swap in 05-09?
has anyone done a 6 spd transmission swap into 05-09 RL?
I want to keep the j35 but swap the 6 speed from newer rl is it all plug and play as far as TCM from newer RL? |
@teh CL , your expertise is being requested.
Only thing plug and play would be that the trans will bolt right up.
As for the ECU, at minimum you'll need to create a jumper harness with your ECU connectors ----> the KB2 6spd connectors/matching ECU. That's simple enough but whether the KB1 will accept the newer ECU is the real question... :shrug: |
so its better to find a totaled kb2 and transfer everything then?
Yea that would help for sure.
If your serious, go the jumper harness route first just in case the car accepts it. |
