6 speed swap in 05-09?
Only thing plug and play would be that the trans will bolt right up.
As for the ECU, at minimum you'll need to create a jumper harness with your ECU connectors ----> the KB2 6spd connectors/matching ECU.
That's simple enough but whether the KB1 will accept the newer ECU is the real question...
kevinf41
Oct 21, 2015 09:25 AM
Liquidflex81
Mar 24, 2012 05:13 PM
