6 speed swap in 05-09?
has anyone done a 6 spd transmission swap into 05-09 RL?
I want to keep the j35 but swap the 6 speed from newer rl is it all plug and play as far as TCM from newer RL?
@teh CL , your expertise is being requested.
The following 2 users liked this post by thoiboi:
projektvertx (10-16-2018),
rlx015 (10-17-2018)
Only thing plug and play would be that the trans will bolt right up.
As for the ECU, at minimum you'll need to create a jumper harness with your ECU connectors ----> the KB2 6spd connectors/matching ECU.
That's simple enough but whether the KB1 will accept the newer ECU is the real question...
kevinf41
10-21-2015 09:25 AM
Liquidflex81
03-24-2012 05:13 PM
