RL Calipers Fit behind 05 TL 17" rims!
#601
Sorry, yeah I believe he's correct. I was looking at your post on my phone and didn't see it clearly.
But to answer your question.. I think the SS lines are worth it. At only ~$100 for a set, that's ~$25 a corner. The brake pedal feels more firm.
I was more confident braking for sure.
azeezp13 (10-10-2012)
#602
ABP-KBP-CBP & ME
Got a pair of RL Calipers for sale in the BM right now if anyone is looking.
https://acurazine.com/forums/car-parts-sale-361/rl-calipers-socal-870464/
#604
shifting at 7k
Ummm. No.
You put the bracket in through the wrong end of the caliper. Also, notches in the bracket go against the knuckle. So if youre looking at the knuckle from the side of the car, youll see:
-Head of bolt
-Washer
-Knuckle
-Bracket
Then the caliper slides onto the bracket. That is:
-Nut
-Washer
-Caliper
-Bracket
The caliper is intended to be a friction fit on the bracket. Do not trim the tabs that appear to contact the bracket first. Just tighten the caliper down further. The tabs are there to bite into the aluminum and create a better fit so the caliper doesnt move around.
-Head of bolt
-Washer
-Knuckle
-Bracket
-Nut
-Washer
-Caliper
-Bracket
#605
Whats up with RDX owners?
Unfortunately I do not.
#610
civicdrivr (02-01-2013)
#611
Can someone plz show me a picturenof the bracket it self on the car bc i put my rl bbk kit on and im having a lil issue with the caliper rubbin with the rotor torrow i will mess with the bracket but i would like to see a picture so i can get an image of what to do
#614
<a href="http://smg.beta.photobucket.com/user/niockboy23/media/IMG_20130130_131239_zps1c7e3cf7.jpg.html" target="_blank"><img src="http://img.photobucket.com/albums/v222/niockboy23/IMG_20130130_131239_zps1c7e3cf7.jpg" border="0" alt=" photo IMG_20130130_131239_zps1c7e3cf7.jpg"/></a>
#617
AM To WDP In My Garage
^ The picture you put up was useless, we don't have ex-ray vision to see how it was mounted to the knuckle assembly nor could we see the side view where the caliper mounts to the bracket.
Now you could help someone else out by stating what the problem was and what you did to resolve it, as someone one else might be going through the same situation.
The following 2 users liked this post by acura_dipset_tl:
05_NBP_TL (02-02-2013),
civicdrivr (02-03-2013)
upnout (02-15-2013)
#620
It can be leaking from the caliper have someone pump on the brakes and. Look at the caliper while they pumping the brakes
#621
#622
So i put my brakes on everything works perfect but when i press my brakes i get a sweaking sound the same sound thay you get when your brakes are done but i have new brakes i really need help bc this sound is geting annoying
#624
I have the yellow stuff my o2 i think it the metal pieces from the pads this weekend im going to see if i can push it back i think thats what touching my rotors
#626
RIP RBP
Originally Posted by acura_dipset_tl;
Did you get the correct ones? Another member here about two pages back on this thread was advice not to use Russell ss brake line in the 3g tl since something about the flairs are different. He went with xlr8 ones.
I was commenting on AuthurL's post in this thread (584 & 587). Guess I should of quoted him.
I was giving my testimony that he is probably right and over time (W/out checking your fluid) the Russell SS brake lines could be dangerous. I'm not replacing them, but if I was to do it over again I wouldn't get Russell.
#627
For those thinking or wanting a Rear BBK the 3g guys have a discussion going on and a couple of us have been doing some research
ENJOY
ENJOY
A larger rear brake kit "could" be benificial from a bias stand point. But the major problem in adapting a brembo 2 or 4 piston caliper would be the thickness of the rear rotors. All cars with rear brembos have ventilated rear rotors. These are over twice as thick (9mm vs 20mm). Try to adapt that to a solid disc Honda rotor and you might just drop the pads out of the caliper as they wear down.
So then you might think, lets step to a ventilated rear rotor. Again now the theory of performance comes into play. A vented rotor is gonna be a bit heavier. And as we all know, un-sprung rotating mass is the ultimate enemy of performance. Plus, the rear brakes do so little work on a FWD, it's kinda pointless to begin with.
Honestly, I would still like to see someone put in the effort to put STI rear calipers onto one of these. BTW: The 04-08 Sti caliper is really the best option. The piston is slightly smaller than the TL's rear piston, which makes the prospect of a larger rear rotor more practical.
04-08 TL Rear caliper & Rotor
04-07 STI rear caliper & Rotor
Interestingly, the 2G CRV has a rotor roughly the same diameter as the STI, with the same hub-register, bolt patern and similar install height as the TL. Perhaps if the internal drum is the same diameter as the TL (170mm), these might work on the TL with caliper adapter bracket.
Wonder if we can get the 350Z Track rear rotor to work with the STI caliper or 350z rear caliper? Though this is a 14" rotor, which if were to be used i would use the 14" front
I havent been able to verify but i think the Genesis Coupe with brembos has the Drum in Hub which is a 330mm dia with 20/18mm thickness Looks like the Equus might too
Genesis Coupe
Equus rear
Genesis Coupe
Equus rear
#628
Hey guys well i put on the rl caliper and red stuff pads with the ebc rotors the black slotted ones and the front brakes are stuck.....they are breaking the whole time i test drove the car i took it apart and grinded down the metal on the pads thinking there was not enough space to move back and forth but i still have the same problem....what can it be?
#629
ok i noticed when i lifted the front the wheels would not spin freely in nuetral....
so i took off the wheels and it spinned fine
so i bolted down the lug nuts without the wheel on it didnt spin
so i then took out the pads and it still didnt spin with the lug nuts bolted down on the rotor
I noticed the rotor was hitting the inside of the caliper with no pads
it looks like a washer would push the caliper in wards towards teh center of the car and fix the rotor rubbing issue
Did I tighten the bracket too much or is the bracket shaved down to much or is it the rotor? what do you think
#630
Maybe i got the wrong rotors from ajusa
Part Number Product Description Qty Unit Price Price
EBC USR7122 Item: Ultimax BlackDash USR Slotted Rotors
Fits: 2006 NISSAN 350Z TRACK; V6; 3.5L; GAS 1 $218.68 $218.68
#631
28.4 mm thick rotors.....its too thick (thats what she said) and 13inch diameter barely clear the caliper ....you can see how it has started to wear on the front and back of the rotor
#633
@ acura_dipset_tl auh finally a response lol i swear the CL community is dying lol but thank you very much i had the same assumption so you ran two of these set ups before? and where would you get the rotors from cause when i was on ajusa webs site it said it would fit a 05 350z
#634
#635
well looks like im SOL with these rotors i have no idea what im gonna do with these
Im willing to buy the better stuff EBC but i need help getting the right ones this time ... do you know if this is the right part number for the EBC rotors I need Part#USR7122 or can you please help me I dont wanna be assed out another $200
#636
#637
ok i called ajusa and i even looked up the 2005 rotors and the 2006 rotors and its the same part number for both USR7122 so i did order the right rotors.... now only thing im thinking the bracket was cut to low where it mounts up with the knuckle.....
or is it possible when i had the new wheel bearing pressed in it was pressed in too mcuh???
#638
#639
I got the bracket from NVA-AV6 directly..... which bolts should i try losening or not over tightening?...I only tried not over tightening the lug nuts but its still would not fit correctly
#640
