What everyone up to?
either way, insist on a fresh "rebuilt tranny" from honda, and not them just replacing the case (not worth it, at least on the main portion), especially since you are not footing the bill
, even say a $500 deductable be worth it, the tranny life basically gets started over
anyways i think it was wrong fluid in the tranny and it just foammed up/over, and came out the vent tube; aka the drip; and you noticed it in time/stopped before it foamed more and left you on the side of the road
and with how ever they fix it, make absolutely sure they use Honda ATF in it, nothing else works
, even say a $500 deductable be worth it, the tranny life basically gets started over anyways i think it was wrong fluid in the tranny and it just foammed up/over, and came out the vent tube; aka the drip; and you noticed it in time/stopped before it foamed more and left you on the side of the road
Did see a Red 01 CLS on Craiglist bout a day ago. They wanted like 8k
so did they say where it seems to be coming from, and one way to kinda tell if the case is too porous or not, was how much fluid was on the case itself, like alot and kinda all over the it (and fresh) (mainly the side of and bottom with the vent tube)(like under the battery and back kinda),OR more like a defined area (too porous), which should have been noticed during previous oil changes (it's not an over night thing like coming out the vent tube)(also it will of had accumulated dirt and such around the area and such, while puking will basically be all fresh fluid (not really, but NO accumulated dirt though)
when i first took the car into acura, they thought they fixed the leak under warranty, but after taking the car out for a test drive, they noticed it was still leaking. so they cleaned off the entire tranny and then placed some kind of dye in the atf to try and pinpoint the leak. they came to the conclusion that it was coming from the top of the trans case. it was a particular spot on the trans case
i'll try asking for a rebuilt tranny and would like one too, but it ends up being the extended warranty company's decision on it.
Not at all. As long as you have a good free flowing exhaust, you need not to replace the pre cats. The reason for me keeping the pre cats is because of emissions standard. Let alone, those pre cats are roughly $400 per cat. You can spend $800 somewhere else instead of those pre cats.
I was going to delete them, but don't want to go thru the hassle when emissions time comes.
Plus if the back pressure isn't going to hurt, which I believe Thien has demonstrated by running his for 8 months, I would gladly take emissions accepted, no tickets, and peace of mind over 12hp.
That's me tho, but if I didn't care... I would look into turbo.
so i just found out that my extended warranty company is NOT going to cover replacing the tranny case since the problem is the casing itself and not a mechanical failure, such as internal parts. the service advisor at mile high acura is going to get the service manager to contact acura again to see if they are willing to help me out.
i'm going to go pick up my car tomorrow morning and take it to a transmission shop to take a look at it.
the shop i'm taking it to tomorrow is called Wizard Transmission, I spoke with Adam and he said he has never seen a transmission with a porous case before. He's gonna look over the entire tranny with me and see if he can diagnosis the problem.
anyways one of us can blow up the internials if you like
, not very hardand as said looking into it coming at the vent tube again
so first i would check to see if it is low (might be hard since a shop did touch it, and might have topped it off), so i would change the fluid out a couple of times, and make sure to use only Honda's ATF, then clean it up/off real well, so you do not see a trace of atf on the outside of the case, then drive it around for a couple of days/weeks and see if the leak returns
qouting you so much, but yes only new cars (might be used also), but they still have to be under the manufacture's warrenty (just the first occurance has to be under warrenty i think though so the problem is recorded), but yeah no extended warrentys for the lemon law
do you guys think this would be worth 14k?
http://denver.craigslist.org/cto/1597896871.html
also for the general mechanical condition it is in also
Think is better than the accord you were looking at. Just a few good and bad when I quickly glanced.
6MT
Faster
Has navi
Sedan (I knew I wanted four doors, not sure if this is something you care about)
Brembo front brakes
TL-S wheels<--you should sell to me
Mileage is not excessive
Fujita CAI
iPod Intergration
H&R lowering springs
But as seller posted, there is the bad:
Front end scraped/chipped<-- idiot or just doesn't give a fuck
passenger side crack <-- "
Needs maintenance <-- scary
ps pump
, normally they don't go bad
but yes t/belt, plugs (should be done at 90k or so, already wasted by then, and be best if the belt was done at 90k also), and the valve adjust, basically the exact same as a 2g tl
, normally they don't go badbut yes t/belt, plugs (should be done at 90k or so, already wasted by then, and be best if the belt was done at 90k also), and the valve adjust, basically the exact same as a 2g tl
part of the t/belt since you already be in there (sorry i just consider that part of the t/belt)(also all idler bearingss for t/belt also) a tensioner would not hurt either, but not absolutely critical,
so basically whenever the t/belt gets done, the waterpump needs to be done too (less labour, instead of going in there twice)
what bullshit, but they are following the contract to the letter though, and
for not letting the dealer trying to charge out your ass, and taking it to an independent shop
, not very hard
a couple of chrysler trannine are too porous, there is an tsb on them, but the area in where they leak is very specific though, it's at the bottom of an untapped bolt hole , and not just the WHOLE case itself
, not very harda couple of chrysler trannine are too porous, there is an tsb on them, but the area in where they leak is very specific though, it's at the bottom of an untapped bolt hole , and not just the WHOLE case itself
qouting you so much, but yes only new cars (might be used also), but they still have to be under the manufacture's warrenty (just the first occurance has to be under warrenty i think though so the problem is recorded), but yeah no extended warrentys for the lemon lawi'm suppose to be hearing back from mile high acura by noon tomorrow after the service manager talks to acura.
the tranny still has the dye they put in it, so it would be very easy to spot the leak.
and damn, mile high acura charges 5100 for a rebuilt tranny. to replace just the middle casing on the tranny would cost 2600.
where is the vent tube located? can it be seen from the top of the engine bay?
for the dye, you proably will need a UV light to see it, otherwise not really able to see it, so kinda pointless to you, unless you got a UV light
and for a whole tranny, at my work it proably be like only 4k or so (i don't do the pricing so don't qoute me), and it would be with a rebuilt tranny from honda/acura also, so no difference other then one being a dealer (and maybe a loaner car, but 2-3 days is not worth $1100 though)(can rent a hertz car for like $20 a day. maybe a shitbox though (aka a chevy cobolt), but will get you from point A to point B though)
and for the case replacement, most of it will just be labour and not any actual parts, other then the case and some seals
