What everyone up to?
TSW Jarama 19x8 +40 offset
Personally, 19's look the best on 3G.
As the offset goes; stock = +45
The lower the number the more it sticks out closer to your fender.
I didn't need to roll my fenders but there is slight-none rubbing in the rear when I have +250lbs of human fat back there. Then again, I'm dropped on Teins.
Steven, let me know if you want pictures.
The Accord uses 85. It does not require 91, but I "Have" to put 91 in mines. The Accord's compression ratio is 10.0:1. Don't know what you J32A2 compression ratio is. Also James, do not put Mobil 1 full synthetic. It burns to fast and will burn the cross hatches on the cylinder walls. You can use Mobil 5000, but do not get full synthetic. If you go with full synthetic, oil pressure drops by a good bit.
7thgen started the comment he can finish it....j/k...i'm not sure myself
i want to put 255's on my 8" wheels (04 a-spec wheels BTW), but i am a 2g though, so should be easier for 3g's since they have larger wheel wells
when the air/fuel mixture goes into the cylinder it is consider a volume of "1", then after the valves close and and the piston starts to compress the A/F mixture, it will compress it 10 times smaller then the original volume (so 0.10 of the previous volume, or 10:1 compression, while still containing everything before)
ummm.... thats air/fuel RATIO, not compression
meh...
2001 CL:
"Acura's 3.2-liter all-aluminum V6 features a forged crankshaft and dome-shaped alloy pistons, with a 9.8:1 compression ratio in the 3.2CL and 10.5:1 in the Type S. "
2001 CL:
Thanks for gettin those pics up Thien. I love these rims...already cleaned 'em off with a towel & water like 3 times this week, LOL! The car was still a little lifted when those pics were taken, the gap isn't bad. It settled quite a bit after the car was on level ground. I might do the aspec drop in the future, but no dinero for that now. +32 offset, IMO perfect fit. Widened the stance by a little, and the tires are sticky as hell. More pics will be up soon...
I can do them, but you won't pass emissions for anything. You will and more likely throw CEL left to right. If you do get the Pre-cat deleltes, you are freeing up too much exhaust flow, and you won't create enough back pressure. Just get a J-pipe and test pipe if you are looking to free up some exhaust flow. If you want more power adders, get the UR crank puley, MDX spacer, and do some porting of your IM. Unless you want to jump straight to the CT S/C.
you basically want minimum back pressure, but having a ever so slight amount of back pressure, just means that the velocity of the exhaust is still up
, wanna at least roll the rears, fronts will have to wait a little bit longer (like end of march or so)
don't got them on the 2g's
