XLR8 Performance Engine Mounts - Acura TL '04-'08 ALL
Old 02-16-2010, 04:37 PM
Former Sponsor
Excelerate's Avatar
Finally they have arrived.
XLR8 Performance’s Engine Mounts were engineered with longevity, performance and value in mind. Many Acura enthusiasts are having issues with broken motor mounts. These mounts are heavy duty mild steel mounts that have been coated with a satin black finish and improved polyurethane bushings that range in firmness. Controlling the durometer of the polyurethane inserts minimizes engine movement. We offer 3 different durometers of inserts, which are available at no additional cost. When ordering, specify whether you want: Street (62A), Strip (75A) or Race (85A) polyurethane inserts. The polyurethane inserts also have a lifetime warranty.
EDIT ADD BY ADMINISTRATOR RON A 18 JULY 2015: THE LIFETIME WARRANTY MENTIONED HERE HAS NOT APPLIED FOR SEVERAL YEARS. THE WARRANTY NOW IS ONE YEAR.
http://store.excelerateperformance.c.../i-300870.aspx
Excelerate is offline
Old 02-16-2010, 04:38 PM
Inaccurate's Avatar
Can you show us a pic with the mount disassembled ?
From the assembled pic, the XLR8 mounts look similar to the Innovative Mounts. What design features do the XLR8 mounts have that will resist or prevent the donut problem ?
If a person initially purchased a set and then decided later that they wanted a different insert firmness, can a person change the insert without a press ? Will the polyurethane inserts be offered separately ?
Inaccurate is offline
Old 02-16-2010, 05:10 PM
"Let's Do This"
salu8819's Avatar
Good questions^^^^.......... how much are the mounts?can we buy them now?
salu8819 is offline
Old 02-16-2010, 05:22 PM
KN_TL's Avatar
^ He's got a link in his post. $300. There has been lengthy discussions about 'in hand' so unless he had one hell of a rush, they're available.
KN_TL is offline
Old 02-16-2010, 05:25 PM
Former Sponsor
Excelerate's Avatar
The urethane on the bushing we use is actually flat so there is more surface area coverage used to absorb the vibration of the engine whereas with a tapered bushing, like the one used by Innovative, you're only pinching the center point of the bushing which will cause it to have more load on that single point. In turn the bushing will start to donut or become oval. Innovative also uses a small bushing whereas the bushing we use is a wider bushing and it is a solid-through bushing so there is more meat on our bushing.
The bushings are pressed in. If you decide you want to change the bushing you would need to use a small press or vise and press the center pin out and then use a punch to force the bushing out. Then you install the new bushings and reinstall the center pin.
Old 02-16-2010, 05:26 PM
"Let's Do This"
salu8819's Avatar
Just looked at the link thanx^. Can u just explain the different stages that are available and what would be best for a fully bolt on TL 6spd w/o precats and s/c
salu8819 is offline
Former Sponsor
Excelerate's Avatar
I have plenty of kits in stock. The kits are going to start at $300 as part of an introductory price.
Old 02-16-2010, 06:29 PM
Fresh23's Avatar
Finally, long awaited, these mounts will be my next purchase.
Fresh23 is offline
Old 02-16-2010, 08:08 PM
"Let's Do This"
salu8819's Avatar
Can u just explain the different stages that are available(62, 75, 85a) and what would be best for a fully bolt on TL 6spd w/o precats and s/c
salu8819 is offline
Old 02-16-2010, 08:51 PM
Inaccurate's Avatar
Can you show us a pic with the mount completely disassembled, showing the inserts removed and showing the flat surface of the bushing ? Please This would go a long way in helping us to understand.
Will the polyurethane inserts be offered separately for those that wish to experiment with the different durometers ? Any idea on the price of individual inserts ?
Old 02-16-2010, 11:02 PM
Former Sponsor
Excelerate's Avatar
62A is for most street cars, even those with bolt-ons. Those who want to minimize vibration will want 62A. The 75A bushing is good up to about 600 hp; of course it adds vibration to the cabin because it is a stiffer bushing but it will also further reduce engine movement and wheel hop.
I don't have a pic of the mount disassembled and I don't have a spare mount that I can disassemble at this moment. If I did it to one of the mounts I have here I wouldn't be able to sell it as new. I'm not sure what more this picture will prove since we have described the bushing already. I can see if I can get a pic from the fabricator.
Yes we can sell the inserts separately. I haven't priced it out yet b/c I've never had to sell multiple bushings to someone. Most ppl just buy what they want from the beginning and keep it in their car. However, I will get answers for you.
Old 02-16-2010, 11:17 PM
18psi
libert69's Avatar
xlr8, i was planning on buying the 85a as opposed to the 75a innovative mounts for the turbo in hopes that they wouldnt donut. If you were in my position would you choose the 75 or 85 xlr8 mounts?
libert69 is offline
Old 02-16-2010, 11:27 PM
Former Sponsor
Excelerate's Avatar
75A XLR8 Mounts. 85A is overkill.
Old 02-16-2010, 11:34 PM
18psi
libert69's Avatar
thats what i was thinking too. will be purchasing real soon. im interested in the p2r thermal block spacer kit (TB and IM). got a link for that? any discount code
libert69 is offline
Old 02-17-2010, 09:23 AM
"Let's Do This"
salu8819's Avatar
The 75a would be more for a aggressive driver than the 62a bc I wouldn't want the 62a to wear out on me. So it be safer to go with a 75 a?
Once again I'm a fully bolt on 6psd w/o precats and s/c.
My stock mounts ripped
salu8819 is offline
Old 02-17-2010, 09:58 AM
Former Sponsor
Excelerate's Avatar
All the prices are already discounted on the P2R parts and the mounts. There is a package under our brand XLR8 and then click on Acurazine packages.
62A is sufficient for most street setups. Those who demand more traction and less engine movement and don't mind the additional vibration should get 75A.
Old 02-17-2010, 10:44 AM
"Let's Do This"
salu8819's Avatar
Thank you For all the help..... I'll be buying these tonight
salu8819 is offline
Old 02-17-2010, 11:06 AM
TYPE-S CBP MT
illstrategy's Avatar
Josh, any combo deals if we buy the mounts and the torque dampner?
illstrategy is offline
Old 02-17-2010, 12:35 PM
Former Sponsor
Excelerate's Avatar
Unfortunately I have all these parts at introductory prices so I can't go much lower. If you buy both I can give you a promo code to take $10 off the mounts.
I have also put up most of the funds to design these parts months ago so I have to recoup some of my costs soon. And if you buy both parts though you will get a reduced shipping cost.
Old 02-17-2010, 08:53 PM
"Let's Do This"
salu8819's Avatar
Mounts have been Purchased!!! cant wait.....
salu8819 is offline
Old 02-18-2010, 09:15 AM
94 DC4 RS LSV/Turbo
stillhere153's Avatar
... I've installed the Innovative Mounts numerous times and I'm well versed as to why oem mounts FAIL...
Looking at the first picture... You automatically see that the XLR8 mounts keeps the design of the oem mounts... Innovative did not and the mounts fail because of it
Josh... Looks like it's going to be a good year for the 3RD Gen Acura TL... You've come out with a load of goodies
stillhere153 is offline
Old 02-18-2010, 09:44 AM
"Let's Do This"
salu8819's Avatar
^^ yea I compared the pics between XLR8 and IM, I must say that xlr8's design looks way more durable and you can tell they did their homework. Two thumbs up
salu8819 is offline
Former Sponsor
Excelerate's Avatar
Yes and there's more to come.
We're also working on a clutch setup and some new brake-related items. When we have more info though we will post it up. Good things to come for 2010.
Old 02-18-2010, 09:48 AM
Inaccurate's Avatar
I am not seeing it
Can you explain more ?
When I look at the assembled XLR8 mount, it looks similar to the Innovative mount. So, I am really interested in what you are seeing different.
Now, I am sure that the XLR8 mount does have a different design on the inside. But just viewing it assembled in the pic.... I don't see what you see. Please help a blind man out
Old 02-18-2010, 11:01 AM
94 DC4 RS LSV/Turbo
ok look at the pictures again... in the IM the bushing is "floating"... XLR8 the bushing is attached to the base and the bracket is "floating" (ie. as oem is)... you tell me which is better
Old 02-18-2010, 10:01 PM
OMGWTF4THGENTL
Kennedy's Avatar
I am not seeing it
Not trying to stir the pot in any way, but I agree...
Understanding how engine rock stresses are applied to the front an rear mount, I fail to see how these mounts won't donut out as well?
The fundamental design appears to be the same... the difference in these mounts seems to be the upper section of the front/rear mounts have the extra support "flap" that folds over the sides. They seem to be "inverted" IM design.
IM: Lower mount with side brackets, upper mount attached to cylinder
EX: Lower mount attached to cylinder, upper mount attached to side brackets.
Both mounts attach together with a single axial bolt through a poly donut.
Unless something is different on the inside of the donut, these mounts appear to be of a very similar nature, and will be subject to the same stresses that's causing the IM mounts to fail.
Seeing one disassembled will help...
Kennedy is offline
Old 02-19-2010, 12:13 AM
94 DC4 RS LSV/Turbo
chris read post 5
IM
XLR8
difference in shapes using earlets
Old 02-19-2010, 03:40 AM
MAS
MAS's Avatar
Originally Posted by kennedy
not trying to stir the pot in any way, but i agree...
Understanding how engine rock stresses are applied to the front an rear mount, i fail to see how these mounts won't donut out as well?
The fundamental design appears to be the same... The difference in these mounts seems to be the upper section of the front/rear mounts have the extra support "flap" that folds over the sides. They seem to be "inverted" im design.
Im: Lower mount with side brackets, upper mount attached to cylinder
ex: Lower mount attached to cylinder, upper mount attached to side brackets.
Unless something is different on the inside of the donut, these mounts appear to be of a very similar nature, and will be subject to the same stresses that's causing the im mounts to fail.
+1
MAS is offline
Old 02-19-2010, 06:48 AM
Inaccurate's Avatar
chris read post 5
IM
I have seen the inside of the Innovative mount for the 2G and 3G TL. And this picture ain't it.
Old 02-19-2010, 07:27 AM
OMGWTF4THGENTL
Kennedy's Avatar
chris read post 5
IM
XLR8
I read that, but must confess I didn't understand... Pics speak volumes... and to your point above about the donut float, interesting, and likely true that it's better on the frame side (the whole unsprung weight in suspension systems), but I fail to see how that addresses the stress issue that's causing the failures in the IM mounts.
My point is innermost section of the mount, the metal sleeve inside the poly that the axial bolt slides through, is the stress concentrator and cause of failure on the IM mounts. Until we see one taken apart on that, I can't see the difference.
One way to think about fixing the IM mounts (which may be in these) is to machine a larger oval/flatttened inner steel bushing to spread the vertical forces across more poly... Just a though. Josh eluded to "flattened" above, but I'm not getting it.
Kennedy is offline
Old 02-19-2010, 11:43 AM
n3o
n3o's Avatar
Wheres the torque damper you mentioned that was gonna be released??
n3o is offline
Old 02-19-2010, 12:06 PM
Former Sponsor
Excelerate's Avatar
You guys are brutal. When the Innovative mounts were released I didn't see this sort of scrutiny. However, in order to show how the XLR8 mounts are better for the TL we did dissect two mounts, one from Innovative and one from XLR8. Both these mounts are from a 2nd gen CL/TL - one is our prototype mount and the other is the Innovative side mount. Both mounts have 60-62A durometer bushings.
Here's a pic of both sample mounts side by side with the bushings removed:
Our collar had to be pressed out. The Innovative collar came out with some force by hand and a socket.
Pics of the bushings. Note that the XLR8 bushing is twice the width.
Even our collar is substantially larger:
Now here is why the Innovative mounts are doughing. I applied the same pressure to both bushings. The red bushing is the Innovative bushing; the black is the XLR8 bushing.
No wonder why the bushings are donuting b/c if I can compress it by hand, with my left hand which is weaker, then I'm sure a motor is doing much worse.
Also here is the pic of the inside of the XLR8 mount:
There is only a 10mm gap between the 2 bushings and that is so you have room to punch the bushing out of the mount.
Innovative makes a thinner bushing and therefore welds in circle plates on the inside of the mounts.
I sell Innovative mounts and I think for the most part they are good quality; however, we designed our mounts for the TL to improve on some of things we felt were lacking in the TL mounts, both for the 2nd gen and 3rd gen.
Old 02-19-2010, 12:07 PM
Former Sponsor
Excelerate's Avatar
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/xlr8-engine-torque-damper-04-08-tl-manual-764069/
Old 02-19-2010, 03:24 PM
Inaccurate's Avatar
We were young and naive back then. The IM experience has made us wiser and more cautious.
The XLR8 inserts do look more beefy than the Innovative. Plus, as you pointed out, the quality of the Innovative polyurethane material was questionable and probably greatly contributed to the doughing. Whereas, The XLR8 polyurethane material appears to be tougher.
I have a question regarding that inner disc in the middle. The hole seems small. It appears that the metal dowel would have little clearance inside the hole. Would the metal dowel make contact with the side of the circle in the middle disc when the polyurethane flexed? If the dowel is allowed to rest against that disc (metal to metal), it seems like a lot of vibration would be transmitted into the car.
Old 02-19-2010, 03:40 PM
"Let's Do This"
salu8819's Avatar
Great write up Josh........ U should be recieving the package monday
salu8819 is offline
Old 02-19-2010, 03:44 PM
Former Sponsor
Excelerate's Avatar
That's not a metal hole. That's the bushing from the other side. There's only 10mm that separates the two bushings.
Old 02-19-2010, 03:53 PM
Inaccurate's Avatar
^ Awesome.
I'm starting to get excited now
Old 02-19-2010, 04:25 PM
OMGWTF4THGENTL
Kennedy's Avatar
Don't be offened... When the IM came out, noone ever dreamed we'd have the problems we're having.
Kennedy is offline
Old 02-19-2010, 05:01 PM
Former Sponsor
Excelerate's Avatar
I'm not offended. I know that once we prove the design to the more investigative members, like Inaccurate and yourself, you will be able to explain to others the benefits and why they should choose our mounts.
Old 02-22-2010, 10:17 AM
HQTL6SPD's Avatar
Wow the design does look better!! Hmmm
HQTL6SPD is offline
Quick Reply: XLR8 Performance Engine Mounts - Acura TL '04-'08 ALL
