Power steering whine on 05 RSX base
Old 02-08-2016, 08:04 PM
3rd Gear
wbwarriors's Avatar
I changed the power steering pump on my 2005 base RSX with a remanufactured ebay purchase, and it's still squealing. Not as bad, but still squealing. If I spray lube into the front bearing of the pump it stops completely for a minute or so. The old pump did the same thing if I sprayed lube into the front bearing - so I thought it was the pump. I don't see any bubbling in the reservoir. I saw some of the posts on leaks in the lines and possibly in the rack, but if the noise stops when I spray lube into the bearing behind the pulley when it's running - do I have a bad remanufactured pump?
Old 02-09-2016, 08:42 AM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
have you tried checking the tension on the belt too? if unit is refurbed and also squealing until you lubricate the bearings inside the pulley, maybe the belt is too tight...
Old 02-09-2016, 10:10 AM
3rd Gear
wbwarriors's Avatar
I didn't realize the tension could be adjusted...the spring on the tensioner pulley just needed to be released to remove the belt and pump...how is it adjusted?
Old 02-09-2016, 11:14 AM
KaMLuNg's Avatar
i'm not familiar with RSXs... i just threw it out there as something to check... so it is an autotensioner... is the belt new correctly sized?
if you spin the bearing with the car and belt off, does it make any noise?
Old 02-09-2016, 11:21 AM
3rd Gear
wbwarriors's Avatar
The bearing did not make any noise when I spun the shaft out of the box.
08-16-2022 05:52 PM
SupremeOpinion
2G TSX Problems & Fixes
02-08-2016 06:16 PM
Keyyss51
02-01-2016 08:04 AM
furnac3
01-30-2016 08:15 PM
lojik
1G TSX Problems & Fixes
01-26-2016 07:51 PM
Quick Reply: Power steering whine on 05 RSX base
