Knuckle seperating?
Old Jan 26, 2010 | 01:53 PM
smithownium's Avatar
Knuckle seperating?
Well not to long ago I went to a mechanic and he said that my knuckle had separated about 4 mm from my control arm. Has anyone had this problem before, if so what can I do to fix this problem? The mechanic has no idea what has caused the problem, but I think it maybe the stress my eibach springs are causing. My other mods are ingalls camber kits front and rear, eibach springs on stock shocks. Thanks for your help.
Old Jan 26, 2010 | 01:57 PM
C25A1guy's Avatar
I can divide by zero
Is this on the front or the rear?
Old Jan 26, 2010 | 02:26 PM
front driver side
Old Jan 26, 2010 | 02:28 PM
C25A1guy's Avatar
So, it's lifting up from the lower control arm, correct?
Old Jan 26, 2010 | 02:34 PM
i'm guessing so, you probably know more than I do. That is just what the mechanic told me.
Old Jan 26, 2010 | 03:16 PM
C25A1guy's Avatar
If that's the case, probably you need a new lower ball joint. They don't sell it separate from the factory (they make you buy entire knuckle assemble without wheel bearings), but there are aftermarket replacement ball joints.
Old Jan 26, 2010 | 03:22 PM
oh ok, good to know. where about can i get an aftermarket replacement ball joint?
Old Jan 29, 2010 | 04:07 PM
any idears on where to find an aftermarket ball joint at?
Old Jan 29, 2010 | 04:55 PM
C25A1guy's Avatar
I've seen some on Rock Auto's web site
HairyMonkey019
Apr 22, 2016 10:50 PM
LoneRonin
Jan 4, 2016 01:03 AM
Pull_T
AcuraZine's Hall of Fame
276
Apr 29, 2008 12:24 PM
Mike 350Z
Dating & Relationships
Jan 9, 2004 02:36 PM
mpgn04
Jul 17, 2003 04:05 PM
