AC issues, compressor stops
Hello all, long time reader, first time poster.
I have an ac issue that's racking my brain. My compressor seems to shut off whenever the system is under load. Runs fine in idle (usually), and shuts off once the car gets going. Some mornings when it's cooler I can get it to stay on for my trip to work.
1. When I hold down the auto and on/off button, I get a code of C1. It doesn't flash with the "88" that I've read elsewhere. Does anyone know what this code pertains to?
2. When the compressor shuts off, the recirculation button is disabled? Does anyone know what causes this error?
2013 ILX Hybrid w/tech, 65,000 miles. When the system is running, it's nice and cool. I have a feeling something is telling the compressor to shut off, but can't figure out what.
Any suggestions?
Any suggestions?
if under warranty, go to the dealer and have them fix it. If you are just out of warranty just go to a Honda/Acura private mechanic guy and just get it fixed. Pay for an oil change at the dealer so they throw in a free multi-point inspection and tell you whats wrong. Get the free estimate, and then go get a second opinion, from a private mechanic. ALWAYS get second opinions and NEVER tell them you are doing that. let them tell YOU whats wrong with the car. If they say something different or the same, get a 3rd opinion if needed. I've noticed mechanics and shops are getting shadier. More and more cars require less and less maintenance. So dealers and mechanics are trying to squeeze every ounce they can. You have time to get a couple different opinions, AC isn't stopping the car from working.
Back in the days, I owned a 2007 Civic that had AC issue working some time and other not working, and after some research, I found out it could be a relay issue, so I change the relay for a made in japan one, and Voila, 8.99$ later it was fix.
So reading your issue, at that price, I would try that route first.
Any suggestions?
Any suggestions?
it's shutting off because it's low on the refrigerant, being a 13 could have a slow leak. put some die in it after topping it up drive around for a few months then inspect using U.V light a goggles. if there's a leak you'll see where it is.
tsx504
1G TSX Problems & Fixes
Mar 16, 2015 10:22 PM
Skunkworkz
1G RL (1996-2004)
Mar 3, 2015 05:57 PM
scottthomp
Sep 3, 2012 08:47 AM
Toddy
Aug 28, 2012 02:16 PM
jlynn80
Oct 29, 2008 12:08 AM
