2014 ILX check starter system?
Old Nov 21, 2014 | 06:08 PM
kaydotem's Avatar
Exclamation 2014 ILX check starter system?
I have a 2014 ILX. It has about 29k miles on it. I just had it in for service a few wks ago - oil change, tire rotation and alignment (I hit a turkey a few days before I went in...).
A few days afterwards, "CHECK STARTER SYSTEM" showed up on my dash board. Looked in the manual and it said to take it to the dealership, so I brought it in later that same day. At that point, the notification went away and the service department said they can't find anything wrong with. This was last week.
My service rep told me to have it towed next time it goes off, so they can find out what exactly the problem is. Ever since then, the notification comes on randomly. I never have an opportunity to have my car towed when it does (due to work, or it being when they aren't opened...would need a loaner car if I tow it there as I am in the field a lot for work). Whenever this notification pops up, whenever I go to turn my car back on, it won't start up right away, it will only go into accessory mode. I end up having to hold the start button in for awhile and then it starts. Then once it starts, the notification is gone. Repeat cycle!!
I googled to see what it could possibly be, because the Acura service department seems to have no idea. Any one else have this problem with their Acura?
Old Nov 21, 2014 | 06:33 PM
usdmJON's Avatar
Sorry to hear. Your best bet is to do as they have asked and get it towed the moment it happens.
I understand it isnt convenient with work but car repairs never are. And fact is when the issue gets more severe you will then be forced to skip work, this time far more stressed because the car isn't functioning period.
Hopefully someone can shine some light on your question better than I have though!!
Old Jul 9, 2015 | 03:49 PM
pedrox05's Avatar
Kaydotem- did you ever find the problem? I'm having the same problem and the dealer did not find anything wrong and message "CHECK STARTER SYSTEM" still comes up once in a while.
Old Mar 26, 2016 | 12:49 PM
MAHONEY507's Avatar
Interesting... I haven't had a message pop up but I have had mine just click when I tried starting it a hand full of times. It always starts the second time I try though.
Old Aug 17, 2016 | 12:41 AM
Venture's Avatar
2014 Acura ILX Dynamic, less than 15000km. Same issue as the rest of you are experiencing. Intermittent problem with the push button ignition, car gets stuck in a loop where it only goes to accessory but will not turn over. If I double click the ignition button to get the electrical system to shut completely off and give it a few moments, it seems to catch and eventually turn the car over. It initially happened to me in winter and I had attributed it to cold weather starting, however the issue has manifested itself even in the hot summer season so it does not appear to be temperature related.
I spoke with the service department at Northwest Acura in Calgary, AB today and the service manager has advised that this problem may be due to a defective 'ignition relay'.
I will post an update as I know more. If anyone has any further information that could help diagnose or find a resolution to the issue, it would be greatly appreciated.
Dash service message displayed.
Old Aug 17, 2016 | 12:56 AM
Midnight Mystery's Avatar
Null and proud of it
Wait, you hit a turkey?
Well, I almost hit a buzzard in June...
Best of luck diagnosing this!!!
Old Oct 2, 2019 | 02:48 PM
Alexander Lebedev's Avatar
Did you find solution? Was it starter issue?
Old Jun 18, 2020 | 02:51 PM
ReneM's Avatar
4th Gear
Hi,
Di you ever find the problem? I have the same issue. I live in Calgary as well.
Thanks!
Old Jun 18, 2020 | 03:04 PM
low voltage from a bad battery can induce the check starter message, as can a bad ground.
Please check battery voltage, please check wires for corrosion, please check starter
Old Jun 18, 2020 | 04:14 PM
Venture's Avatar
This is interesting feedback. For the last 6 years this issue has persisted - no dealership has been able to successfully mitigate the problem. I will take the car into a battery retailer and see what they come up with for the voltage.
Appreciate the insight!
Old Jun 22, 2020 | 09:43 PM
Originally Posted by ReneM
Hi,
Thanks!
Yes. I replaced starter and problem is gone.
Old Jun 22, 2020 | 11:25 PM
DaIll1's Avatar
Good information in here
I love it when people post a fix
Sticky worthy
Old Nov 17, 2020 | 07:38 PM
ReneM's Avatar
4th Gear
My 2015 ILX 2.4 had the same warning light on the dash this summer. Today I took it to the dealership for an A1 service and they scanned the vehicle. Found code P16F7. They updated the PGMFI software.
https://static.nhtsa.gov/odi/tsbs/20...07088-9340.pdf
nutbroker
Sep 21, 2017 04:14 PM
Randy99CL
1G CL Problems & Fixes
Mar 10, 2015 12:46 PM
badluckrad
May 14, 2013 10:30 AM
thku4grace
1G TL Problems & Fixes
Mar 8, 2007 12:03 PM
Rumble
1G TL (1996-1998)
18
Aug 13, 2004 09:18 PM
