Knocking/Popping after H&R Spring install
Old Jul 13, 2013 | 09:43 PM
ilxdrop's Avatar
8th Gear
Hey guys,
Installed the H&R lowering springs the other week. Car looks amazing, however I noticed that when doing hard turns (left and right) there is a pop or a know that happens when traveling at low speeds. Not sure what is causing this.. has any one experienced this and is there any guidance for what to fix?
Old Jul 13, 2013 | 10:05 PM
usdmJON's Avatar
Sounds like what happened to me. I figure this is mcberl.
We only checked on two things and it was one of the two.
Make sure the CV Boot is in its proper position. There should be a mark of paint on the boot and the axle to show how far up the boot sits. Make sure that isn't twisted or caught up on the axle.
Also make sure the axle itself is properly seated. I don't have knowledge on what it feels like when the axle pops in or out, my buddy did, but he seems to think it was the CV Boot, not the axle. Good luck!!
Old Jul 13, 2013 | 10:25 PM
ilxdrop's Avatar
8th Gear
Haha good guess. I took a look at that cv boot. Both sides are in proper position. The sound is resonating closer to the top the spring inside the wheel well (passenger side mostly), up in the upper mount. Now that I have the wheels off and lifted it almost sounds like a a ting...
Old Jul 13, 2013 | 10:36 PM
ilxdrop's Avatar
8th Gear
It's for sure up on the upper portion of the spring. I'm thinking possibly the damper assembly? I'm a little perplexed still seemingly as I had it installed professionally.
Old Jul 13, 2013 | 11:02 PM
usdmJON's Avatar
Weeeeird. Bring it back and tell them what youre hearing. At least you didnt do it. That would suuuuuck.
Old Jul 14, 2013 | 10:25 AM
JMJ3rd's Avatar
'06 RL Tech
Old Jul 14, 2013 | 01:11 PM
Switt23's Avatar
Sounds like when they put the spring on they didn't make sure that it was seated correctly up against the spring seat. When you turn the wheel the weight of the car shifts onto one spring more than the other and the spring slips in the seat slightly making a "ting" or "dong" style noise.
Old Jul 14, 2013 | 02:49 PM
usdmJON's Avatar
Bam.
Old Jul 14, 2013 | 03:15 PM
JMJ3rd's Avatar
'06 RL Tech
Thanks for all the heads-up's! I'll know what to tell the installers to make sure of when I have mine done.
Old Jul 14, 2013 | 04:02 PM
usdmJON's Avatar
lol imagine his reaction when you tell him how to do his job.
Old Jul 14, 2013 | 04:46 PM
JMJ3rd's Avatar
'06 RL Tech
I won't birddog them, at least they'll be aware that I'm aware!
Old Jul 14, 2013 | 08:05 PM
Switt23's Avatar
This is a big picture but it shows what I am talking about...
http://www.carsteering.com/data/all_images/75-80068-Map.jpg
If you look at the very bottom coil of the spring, you will notice the bottom mount has a notch in it that holds the spring tight. If the spring is not seated all the way up against that "wall" or "seat" when the spring uncompresses it has wiggle room and makes noise .
It could however be other things, but that would be my guess if you have no other symptoms.
Old Jul 14, 2013 | 09:48 PM
ilxdrop's Avatar
8th Gear
That's awesome! Ill have to take a look as soon as I get back!
Old Jul 18, 2013 | 06:11 PM
ilxdrop's Avatar
8th Gear
just got back from picking up the car from the shop that installed the springs. According to them the shock is what is causing the noise and not the spring. They indicated that the seal inside the shock is binding every time the wheel turns left or right... His suggestion was to replace the shock with either factory or an after market. He said that he couldn't get the part from the dealer here in town because they didn't have any in.
I'm thinking that going aftermarket would be the way to go at this point.. Does anyone have any suggestions for after market shocks? or alternate ideas?
Old Jul 18, 2013 | 07:38 PM
usdmJON's Avatar
Koni yellow knoi yellow and koni yellow.... illuminas are nice too but I suggest the yellows.
Old Jul 18, 2013 | 10:27 PM
ilxdrop's Avatar
8th Gear
Any specific reason? What's the plus to yellows? And where do you order them from?
Old Jul 19, 2013 | 12:15 AM
chinoxii's Avatar
You can get it from here:
https://www.redshiftmotorsports.com/...spPackages.htm
dang, your car is not even a year old, how come they blame the suspension causing the noise? They made a bad install and they blame your suspension instead.
Old Jul 19, 2013 | 03:19 PM
neveronlineilx's Avatar
^ thats wjat I was thinking too. Either that or a heck of a coincidence???
Old Jul 19, 2013 | 05:22 PM
chinoxii's Avatar
I would not spend a dime until I get second opinion from other mechanic. I am 99% sure the shock is fine lol.
Old Jul 19, 2013 | 08:56 PM
usdmJON's Avatar
Search google for Koni Yellows and find them in a 2012+ civic spec, si if you have a 2.4 and the civic 1.8 for the ilx 2.0 owners.
JHP is a good source.
Weksos.
If I remember correctly eibach sells koni struts.
And a quick search showed tire rack has a 20% sale on konis right now... same for the link chinoxii posted (not sure on redshifts sale price)
Judging by the fact that like 6 or so users are experiencing the same sound issue on a completely stock suspension shows its probably infact not the mechanics fault. And their straight forward response was more solid than anything acura has been able to give these users. Might be something there since this mechanic doesnt have to worry about saving acuras ass.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
jmoney2001
Aug 12, 2019 06:23 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
SinCityTLX
63
Mar 23, 2016 02:13 PM
