Help! Trunk wont open with FOB or button on the trunk, only with the inside release l
Old Aug 22, 2020 | 12:06 PM
dezdigital's Avatar
Hello, Just seeing if anyone can help me out with this issue.. I've ruled out that it's definitely not related to the valet switch which is located in the glove box or the trunk key lock near the release lever.. I can hear the trunk trying to open but it just will not. The only way I can open the trunk is by pulling he only way I can open the trunk is by pulling the the release lever located near the driver's seat. Is it safe to assume that I need an actuator or possibly spring release? Thank you in advance for any assistanceHello,
I can hear the trunk trying to open but it just will not. The only way I can open the trunk is by pulling the release lever located near the driver's seat.
Old Aug 22, 2020 | 12:33 PM
the art of solving problems is the art of visual intelligence.
pop the trunk and look at the latching mechanism, try to activate it with the FOB....what do you see going on? I dont have an answer for you, just helping you diagnose the issue
Old Aug 22, 2020 | 03:15 PM
Paulcet's Avatar
6th Gear
Yes, you probably have a problem with the actuator. As above, LOOK at it, you may find something loose or worn.
JR_Rider
5G TLX Problems & Fixes
Jan 29, 2017 02:50 AM
02 TL
Sep 3, 2012 11:52 PM
mr_sangbang
Apr 22, 2012 10:44 PM
S2000 GUY
Aug 29, 2011 09:13 PM
peakyfreak80
2G CL Problems & Fixes
Aug 21, 2010 01:14 AM
