Trunk Won't open - Save My Beer
Old Nov 8, 2009 | 02:28 PM
S2000 GUY's Avatar
DMB!
Hey guys,
Just back from a trip to Boston picked up a case of my favorite local IPA beer at $10 a six pack put it in the trunk with the rest of my crap got hime and found my trunk won't open.
The button on the key fob works and you can hear it function but it doesn't release, same with the trunk release button inside the car - it functions but the trunk won't "pop".
HELP my beer is in there!
Old Nov 8, 2009 | 02:36 PM
Toddy's Avatar
Registered Member
fold down your arm reast and reach in there and pull the emergency release. Should make it open. Otherwise grab each beer one by one out of the pack through the hole...
Old Nov 8, 2009 | 03:03 PM
greco9885's Avatar
in the glovebox there is a switch, make sure u didnt turn it off
Old Nov 8, 2009 | 03:15 PM
S2000 GUY's Avatar
DMB!
I moved around enough stuff and got the emergency release with a broom stick through the pass through.
So there is a swich in the glove box? have to check it out.
Old Nov 8, 2009 | 03:38 PM
Aman's Avatar
Your Friendly Canadian
You said you locked it in your truck. What kind? Or did you mean the trunk of your TL?
Old Nov 8, 2009 | 04:11 PM
n0rm's Avatar
I ♡ PEK PEK
If all else fails take off your back seat...
Old Nov 8, 2009 | 04:48 PM
shooter's Avatar
Acuras Only in
Even if you flick the lock in the glovebox, you should still be able to open the trunk using the fob key ..
Old Nov 8, 2009 | 05:26 PM
HQTL6SPD's Avatar
Happened to me once when I overtightened the latch.
How 2 open:
Stand back to back with your trunk, push into the lower area of the trunk with your ass while you press the trunk open button
Sounds funny, but it might work for you too lol
Old Nov 8, 2009 | 05:54 PM
Aman's Avatar
What does that do?
Old Nov 8, 2009 | 07:51 PM
BoxOn20s's Avatar
When the striker is adjusted too deep or is hit causing it to move, there is a lot of tension on the latch mechanism which doesnt allow the latch to release. By putting weight on the trunk lid, it compresses the weather strip and helps to reduce that tension allowing the latch to open.
Old Aug 29, 2011 | 08:38 PM
duffduffxx's Avatar
Did you ever figure out the solution to this problem?
Old Aug 29, 2011 | 09:13 PM
guitarplayer16's Avatar
Yeah I think he took a broom stick to open the trunk through the arm rest.
Beer saved.
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
VA2000TL
Oct 2, 2015 08:26 AM
brandnewcolony
Sep 12, 2015 10:39 AM
