Trunk lock
Old Apr 22, 2012 | 07:32 PM
mr_sangbang's Avatar
Cool Story Bro
Trunk lock
my trunk won't open anymore. is there a way to fix it? help me thanks
Old Apr 22, 2012 | 07:45 PM
Will Y.'s Avatar
Registered but harmless
You're not giving us any information with your problem-- what steps did you take to try to get the trunk to open?
Use the fob, or just the dash-mounted switch?
Can you hear any clicking from the trunk when you push the button to open the trunk?
in the absence of other info, try changing the position of the glove compartment trunk lock switch.
Old Apr 22, 2012 | 08:28 PM
Cool Story Bro
i tried everything. the dash switch and the fob. still nothing. i tried to use the emergency release switch from the trunk but cant reach it. my sub box is to big
Old Apr 22, 2012 | 10:07 PM
Will Y.'s Avatar
Push down on the trunk lid, then hit the fob trunk release button-- is there any "click" or noise?
If yes, you have a mechanical problem, like a loose latch that must be resolved after getting the trunk open.
If not, see this thread for wiring diagram and potential culprits: https://acurazine.com/forums/showthr...=trunk+release.
Originally Posted by sangvo85
...i tried to use the emergency release switch from the trunk but cant reach it. my sub box is to big
If you can see an emergency trunk release handle, maybe you can use a grabber or twist a coat hanger to reach it.
Old Apr 22, 2012 | 10:44 PM
MyFreakGSR's Avatar
Have you had the pollen filter replaced recently? Pull the switch out from the glove box and see if its plugged in. If its not, you should be able to flip the glove box down and reach your fingers through the hole on the left side and find the connecter and plug it in.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
