HELP - HD Box / TV connection
Old Sep 3, 2008 | 10:21 AM
ThermonMermon's Avatar
I thought i was electronically savvy until yesterday...i cannot for the life of me get my HD box to work with a new LCD.
Cable box is TimeWarner Scientific Atlantic 8300HD.
TV is 32" Sharp 720P LCD.
I already have all the colored cables, and would truly prefer not to deal with buying HDMI cables, regardless of quality diff.
i have tried all combinations for connecting the cables...could get sound working but no picture.
ANY ADVICE IS HELPFUL. (spent 2 hours working on this. and REFUSE to deal with NYC TimeWarner service, as any NYers may know).
THANKS GUYS!
P.S. the box should work, as it used to be hooked up to my roomates 1080i.
Old Sep 3, 2008 | 10:45 AM
STL+3.0CL's Avatar
Matt
Any sound? You have your component (colored) cables going from the HDbox to the TV and have the TV tuned to the component input, and you get a black screen with no sound?
Old Sep 3, 2008 | 12:42 PM
i DO get sound, but no image. well there is an image, but its split up into thirds, is black and white, and is fuzzy. (if that counts)
its not the TV, it works fine when hooked up to the same box with a coaxial. and its not the colored cord, bc i have tried many multiple ones.
Old Sep 3, 2008 | 12:56 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Change the setting on your box for component out
Old Sep 3, 2008 | 01:31 PM
care to elaborate??
PS. i cant get the Scientific menu up on the screen.
thanks
Old Sep 3, 2008 | 01:48 PM
^^ Can't help you if you cant access the settings menu on your box.
Call your cable company.
Old Sep 3, 2008 | 02:53 PM
Type Sun's Avatar
Big up ya self, BO!
Hook up your tv with coax cable and try to change the settings of your box to component output like Moog said. Otherwise, you'll have to call the catv company.
Old Sep 3, 2008 | 03:51 PM
^^^great idea.
i think the problem is that the box is set to 1080, per the previous TV setup
(current tv is a 720)
Old Sep 3, 2008 | 07:44 PM
nope, cant access the setup menu in coax.
ill just watch non HD. the TV is good enough for me...dont feel like messing with ignorant TimeWarner people.
thanks anyway guys.
Old Sep 3, 2008 | 07:58 PM
Jonesi's Avatar
In the meantime, purchase a HDMI cable and spend the $10-$15..
http://www.monoprice.com/products/pr...seq=1&format=2
Old Sep 3, 2008 | 08:25 PM
Type Sun's Avatar
Big up ya self, BO!
Go to this website http://www.scientificatlanta.com/pro...orer8300hd.htm and choose 'Explorer HDTV Setup Wizard' pdf. It explains how to set up the correct resolution on your model cable box to match your tv.
Old Sep 3, 2008 | 08:46 PM
2001AudiS4's Avatar
Press the info and guide button at the same time on the box, while the box is off. This will take you into the setup wizard. You should then press a series of buttons as it asks you a few questions. If memory serves correctly, the series is B, A, B, B, A (I might be off and this is with a SA box programmed for Cablevision, but i believe the Wizard should be the same). I am surprised that your tv does not correctly upconvert/downconvert the resolution. I typically see a pinkish screen when the box is setup for Standard Def until you run the wizard, not a black and white with the picture breaking up.
Old Sep 4, 2008 | 08:01 AM
Thanks man, found this on the Scientific website PDF a few days ago. Supposedly my INFO and GUIDE buttons do not work.
ANYWAYS, i miraculously got it to work last night...somehow...
THANKS FOR EVERYONES HELP. i hate techie crap like this. esp. when i cant figure it out.
Old Sep 4, 2008 | 08:49 AM
Pete1burn's Avatar
For the newer boxes you can just hit guide while the cable box is powered off and that'll bring you into the setup menu.
Old Sep 4, 2008 | 05:27 PM
2001AudiS4's Avatar
Cool. If you have issues in the future, shoot me a pm. It's what I do for a living afterall.
Old Sep 4, 2008 | 05:32 PM
2001AudiS4's Avatar
I'm curious how you got around this issue (if that was the problem) without being able to access the wizard?
Old Sep 6, 2008 | 02:23 PM
seriously, it was a trail and error of the order of the procedure between turning on what component first / plugging in cables / changing TV input.
again, somehow the right order worked...no wizard necessary. of course, i wouldnt recommend this...
mlody
Dec 4, 2019 02:11 PM
LoneRonin
Jan 4, 2016 01:03 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
