Cool down entertainment center electronics?
Old Sep 27, 2008 | 07:53 PM
bent09's Avatar
horny =
Anyone know of a way to cool down electronic that are enclosed in a entertainment center?
I have an entertainment center and the xbox360 plus the Sat reciever get very hot and overheat.
I can not leave it open because I have a toddler that could hit his head or pinch a finger.
Any advice?
Old Sep 27, 2008 | 09:02 PM
doopstr's Avatar
I drilled some rather large holes behind the equipment. Didn't seem to help much. One day I was planning on putting in a couple fans.
Old Sep 27, 2008 | 09:18 PM
leftride's Avatar
i want to ride my bicycle
I don't have personal experience, but have a friend who has put fans in his cabinets. you could look into something like this:
http://www.smarthome.com/8734FCC/Cab...-System/p.aspx
Old Sep 27, 2008 | 09:32 PM
2001AudiS4's Avatar
Just head over to radio shack and pick up a dc computer fan. They also sell a power cord you can splice onto the fan cord. Drill out your cabinet with a 4 inch hole saw, and then screw the fan with some 2 inch long sheet rock screws or something else that is long enough and self tapping. make sure the fan is pushing the air out and not bring air in. Don't drill extra holes as this will be less effective. We do this quite often in cabinets where customer's equipment heats up. We used to do it more when we sold Harman Kardon. They had a high failure rate do to heat, and the fans substantially cut down on the rate of failures.
Old Sep 28, 2008 | 06:50 PM
bz268's Avatar
Because Of You
I put couple of used 80mm - 92mm computer fans there to suck out the heat. I use one of those tiny multi-voltage power supply. I usually set the power supply to 4.8v and plug it to the AV receiver.
I used to use a 120v AC 92mm cooling fan from Radio Shack . But that was too noisy.
vpasla1
Sep 17, 2016 07:24 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
dirleton
Sep 29, 2015 08:26 AM
