Loo issues
Old Dec 28, 2010 | 12:49 PM
stogie1020's Avatar
Needs more Lemon Pledge
Loo issues
My toilet runs. Almost all the time.
The insides look like:
The rubber hose from the left side to the right side is what is almost always piping water down the tube, and thus into the bowl.
These new-fangled toilet guts have me confused. What do I do?
Old Dec 28, 2010 | 12:59 PM
doopstr's Avatar
Need more info.
If the hose is running then the tank should also be trying to fill with water. Is the water in the tank spilling into the same hole that the hose pumps into? If so then you just need to adjust the shutoff level of the fill valve.
These things usually boil down to adjusting something or replacing the fill valve and/or flapper.
I've done this stuff successfully and my plumbing skills are low.
Old Dec 28, 2010 | 01:01 PM
dallison's Avatar
registered pw
i just bought a new toilet and that solved my problems.
Old Dec 28, 2010 | 01:21 PM
stogie1020's Avatar
Originally Posted by doopstr
Need more info.
The water level is at the very top of the flush valve tube, but not spilling over. I guess I just don't have any idea how to adjust these new systems...
What do I do?
Old Dec 28, 2010 | 01:26 PM
stogie1020's Avatar
All the repair stuff I see online is for the old ball float style toilets...
Old Dec 28, 2010 | 01:43 PM
svtmike's Avatar
The problem is most likely the flapper valve. Replace it and see if it still runs constantly.
Old Dec 28, 2010 | 01:44 PM
The Dougler's Avatar
Unofficial Goat
If the flapper is seated correctly then you need to adjust the fill valve. There should be a screw that allows you to adjust it up/down. In this case you need to adjust it down until the water stops. It should only take 1-2 turns.
Old Dec 28, 2010 | 01:46 PM
Unofficial Goat
this should do ya. again check the flapper first.
http://www.youtube.com/watch?v=CrGy3at4i68
Old Dec 28, 2010 | 01:47 PM
stogie1020's Avatar
Flapper is OK, the water leaking into the bowl is from the small tube that points into the top center of the ?flush tube? in the middle. When I pinch it off, the flow into the bowl stops.
I will look for an adjustment screw when I get home. I am guessing that the water level in the tank should not be at the very top of this center tube?
Old Dec 28, 2010 | 01:50 PM
Unofficial Goat
Should be just below. Yours may not have a screw and could be like the one in the video I posted.
Old Dec 28, 2010 | 02:07 PM
stogie1020's Avatar
Thanks Dougler!
I found a video for the exact style I have. Looks like it;s the same procedure as you posted. 1/4 Turn counter clockwise to unlock and adjust height. I will give it a shot tonight.
http://www.youtube.com/watch?v=PF6gKvlxICA
Old Dec 28, 2010 | 03:46 PM
KaMLuNg's Avatar
check the flapper first... it should have some silicone on the bottom that seals any leaks into the bowl while it is closed... i suspect you have a leak there which is causing the fill valve to continue to run since the water level doesn't reach the top of where it is set to...
Old Dec 28, 2010 | 04:28 PM
jupitersolo's Avatar
nnInn
You need to change out the entire flush valve assembly. I had same problem while back, couldn't find leak nor would adjustment do it.
And if you're calling it a loo, more problems than just water.
Old Dec 28, 2010 | 06:13 PM
svtmike's Avatar
Could be the flapper is fine and there's some foreign object keeping it from closing completely. Stick your hand down there and feel around.
Old Dec 28, 2010 | 06:26 PM
stogie1020's Avatar
Mike, You suck.
Big time.
Old Dec 28, 2010 | 06:40 PM
dallison's Avatar
registered pw
Old Dec 28, 2010 | 08:59 PM
nnInn
:zing:
Old Dec 29, 2010 | 10:34 AM
KaMLuNg's Avatar
wow... so stogie u fix it?
Old Dec 29, 2010 | 12:20 PM
stogie1020's Avatar
Going to take your advice and replace the flapper and see if that solves it. If not, I will replace the fill valve too. If that still doesn't work, I may just shit in the yard from here on out.
Old Dec 29, 2010 | 01:02 PM
endo022's Avatar
Just don't pick this hole in the ground
Old Dec 29, 2010 | 01:21 PM
dom's Avatar
dom
Old Dec 29, 2010 | 03:46 PM
stogie1020's Avatar
Endo,
may you slip and fall on a grape at the grocery store and fall face first into the sweaty butt crack of an obese Jenny Craig dropout on her way home from her "Ass Sweats A Lot Anonymous" meeting...
Old Dec 29, 2010 | 04:58 PM
endo022's Avatar
So...that's where you get your rebound chicks from
You sure it wasn't her that caused your toilet leakage problems to begin with
weight watcher reject --> <---Stogie
I'll be sure to watch out for those pesky once in a lifetime random hazardous grapes...thanks for the heads up
Old Jan 3, 2011 | 03:34 PM
Moog-Type-S's Avatar
The sizzle in the Steak
upper deckers usually stop the leaks....try it.
Old Jan 3, 2011 | 07:05 PM
stogie1020's Avatar
Flapper replaced. Here's hoping that solves the problem...
Old Jan 4, 2011 | 12:36 PM
stogie1020's Avatar
Flapper seems to have fixed the issues. Woot.
Old Jan 4, 2011 | 01:05 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Flapper, no you need a fluffer!
Old Jan 4, 2011 | 01:28 PM
stogie1020's Avatar
Flapper = 1930's fluffer!
Old Jan 4, 2011 | 01:53 PM
9 times out of 10 a new flapper will fix your problem.
Old Jan 4, 2011 | 02:00 PM
NSXNEXT's Avatar
If you don't see water on the floor, the only other place it could be leaking from is the flapper.
Old Jan 4, 2011 | 03:26 PM
dallison's Avatar
registered pw
nice work, hopefully the spider eggs in the tank water didn't get under your fingertips and won't hatch and have a million little under therm
Old Jan 4, 2011 | 03:28 PM
stogie1020's Avatar
You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck You suck.
Old Jan 4, 2011 | 03:55 PM
dallison's Avatar
registered pw
just sharing the love
Old Jan 23, 2011 | 08:40 PM
stogie1020's Avatar
Not sure if it was the toilet or the 1/2 reduction in lawn watering time, but I just got my water bill and it is OVER 50% less than the same month last year.
Old Jan 24, 2011 | 09:33 AM
dallison's Avatar
registered pw
Old Feb 21, 2011 | 11:53 PM
Mizouse's Avatar
the chain that connects the flapper to the darn handle that flushes the toilet keeps coming off, how do i get it to stop falling off?
super glue?
Old Feb 22, 2011 | 01:05 AM
Will Y.'s Avatar
Registered but harmless
super glue?
Just bend the little metal hook on the chain so that it doesn't slip off.
If that doesn't work due to corrosion or a cracked rod, go to a hardware store or Home Depot and buy the toilet handle, rod and chain part-- it's only a few dollars, IIRC.
Old Feb 22, 2011 | 05:10 AM
csmeance's Avatar
super glue?
you could gettho rig it and just take one of those wire ties (like the small ones they put on loaves of bread and stuff) and twist one onto the handle and as well another onto the flapper. Quick, easy and cheap repair!
Old Feb 22, 2011 | 04:06 PM
Mizouse's Avatar
I may have to do that. The way the handle is designed the hook can't be clamped shut, it like just clips into the handle.
With enough wiggling I could come off again.
(that's what she said... but not to me)
Old Mar 16, 2013 | 01:28 PM
stogie1020's Avatar
OK, new issue...
As mentioned above, I have the Korky style filler valve assembly (http://www.homedepot.com/p/t/2021838...2#.UUS3vxzvv2s).
When I flush the toilette, it flushes fine but then as it starts to refill, it starts and stops the process. It finishes, but in a stooping and starting fashion, such as "start", "stop", "start", "stop","start", "stop", etc. about three or four times until the tank is full. Then it STFU and sits there all style waiting for me to flush...
Any ideas why it would stop and start while refilling the tank?
